Following PCIe Endpoint Mode — Jetson Linux Developer Guide documentation and using latest JetPack 5.1, getting low speeds ~5Gb/s relative to theoretical for PCIe 4.0 x8 which is ~128Gb/s. Uplink and downlink speeds initiated from either end are mostly symmetrical. Orin is set to max power.
iperf3 -c 192.168.2.1
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 482 MBytes 4.04 Gbits/sec 0 1.97 MBytes
[ 5] 1.00-2.00 sec 481 MBytes 4.03 Gbits/sec 0 1.97 MBytes
[ 5] 2.00-3.00 sec 476 MBytes 3.99 Gbits/sec 0 1.97 MBytes
[ 5] 3.00-4.00 sec 479 MBytes 4.02 Gbits/sec 0 1.97 MBytes
[ 5] 4.00-5.00 sec 476 MBytes 3.99 Gbits/sec 0 1.97 MBytes
[ 5] 5.00-6.00 sec 475 MBytes 3.99 Gbits/sec 0 1.97 MBytes
[ 5] 6.00-7.00 sec 425 MBytes 3.57 Gbits/sec 0 1.97 MBytes
[ 5] 7.00-8.00 sec 438 MBytes 3.67 Gbits/sec 0 1.97 MBytes
[ 5] 8.00-9.00 sec 465 MBytes 3.91 Gbits/sec 0 1.97 MBytes
[ 5] 9.00-10.00 sec 470 MBytes 3.94 Gbits/sec 0 1.97 MBytes
[ 5] 0.00-10.00 sec 4.56 GBytes 3.91 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 4.56 GBytes 3.91 Gbits/sec receiver
iperf3 -s
[ 5] 0.00-1.00 sec 749 MBytes 6.28 Gbits/sec
[ 5] 1.00-2.00 sec 523 MBytes 4.38 Gbits/sec
[ 5] 2.00-3.00 sec 436 MBytes 3.66 Gbits/sec
[ 5] 3.00-4.00 sec 453 MBytes 3.80 Gbits/sec
[ 5] 4.00-5.00 sec 447 MBytes 3.75 Gbits/sec
[ 5] 5.00-6.00 sec 457 MBytes 3.84 Gbits/sec
[ 5] 6.00-7.00 sec 666 MBytes 5.59 Gbits/sec
[ 5] 7.00-8.00 sec 785 MBytes 6.58 Gbits/sec
[ 5] 8.00-9.00 sec 795 MBytes 6.67 Gbits/sec
[ 5] 9.00-10.00 sec 785 MBytes 6.58 Gbits/sec
[ 5] 10.00-10.00 sec 1.19 MBytes 2.94 Gbits/sec
[ 5] 0.00-10.00 sec 5.95 GBytes 5.11 Gbits/sec receiver
From lspci logs it looks like RP is downgraded to 8GT/s but EP is also downgraded to x1?
RP.eth0.log (4.3 KB) LnkSta: Speed 8GT/s (downgraded), Width x8 (ok)
EP.eth1.log (4.7 KB) LnkSta: Speed 2.5GT/s (downgraded), Width x1 (ok)
Does virtual Ethernet use DMA?
Do higher speeds require patching Orin EP or PC RP kernel or tvnet, or PCIe or Ethernet buffer sizes?
