We have DMA driver in kernel source but not enabled by default. To enable this,
- Enable the same by adding below lines in defconfig(arch/arm64/configs/defconfig) file
CONFIG_PCIE_EPF_DMA_TEST=y
CONFIG_TEGRA_PCIE_DMA_TEST=y
⢠First one enables PCIe End-Point function EDMA test framework to validate on EP side
⢠Second one enables PCIe EP driver on Root-Port to validate on RP side.
- Enable Jetson Orin EP side (this part is same as official document)
cd /sys/kernel/config/pci_ep/
mkdir functions/tegra_pcie_dma_epf/func1
echo 0x10DE > functions/tegra_pcie_dma_epf/func1/vendorid
echo 0x229a > functions/tegra_pcie_dma_epf/func1/deviceid
echo 16 > functions/tegra_pcie_dma_epf/func1/msi_interrupts
ln -s functions/tegra_pcie_dma_epf/func1 controllers/141a0000.pcie_ep/
echo 1 > controllers/141a0000.pcie_ep/start
- Before performing EDMA test
Framework:
Once Driver are enabled and platform is booted. Each driver creates its own debugfs directory.
For EP directory is: /sys/kernel/debug/<contorller_addr>.pcie_ep_epf_dma_test/
example: PCIe C6 EP controller can be referred at /sys/kernel/debug/141c0000.pcie_ep_epf_dma_test/
For RP directory is: /sys/kernel/debug/:01:00.0_pcie_dma_test/
example: PCIe C5 RP controller can be referred at /sys/kernel/debug/0005:01:00.0_pcie_dma_test/
Configuration:
Configurable parameters are referenced via files.
edma_ch ā used for configuring number of EDMA channels and their modes. Bit definition is
⢠[0:3] - To set mode of RD/WR channels. 0-Sync, 1-Async
⢠[4-7] - To enable RD/WR channels. 0-Disable, 1-Enable
⢠31 - is used to enable Remote EDMA mode
⢠30 - is used to trigger ABORT use-case validations
⢠so value of 0xF1 means. all channels enabled for WR mode with channel 0 in async and rest of the
channel in sync mode.
⢠Note: During testing, If an async channel is selected first and then sync channel, high chances
that bandwidth is shared between these channels.
⢠For effective bandwidth Calculations, ensure that all channels are enabled in same mode
only(Sync/Async).
nents ā number of descriptors to be populated in each DMA submission(tegra_pcie_edma_submit_xfer API
call).
⢠When more than one DMA channel is enabled, these nents are splitted for those many channels.
example : if nents = 2 and edma_ch = 0x3, each DMA channel gets one nent each
⢠Note: nents*dma_size cannot cross 127MB
dma_size ā used to specify size in bytes to be transferred in each SW transaction.
stress_count ā used for indicating how many number of SW transaction needs to scheduled in one
execution.
- Start to test DMA performance
Configure below settings of 16Mb size and single channel in async mode for 1000 iterations of 4 nents.
echo 16777216 > dma_size
echo 4 > nents
echo 1000 > stress_count
echo 0x11 > edma_ch
cat edmalib_test
If the test is done correctly, dmesg will have the bandwidth information.
