Hi Wayne,
i disconnected Wlan, connected Ethernet Lan
@ubuntu:~$ lspci -v
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 64
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 00001000-00001fff [size=4K]
Memory behind bridge: 40000000-400fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities:
Kernel driver in use: pcieport
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Subsystem: AzureWave RTL8822CE 802.11ac PCIe Wireless Network Adapter
Flags: bus master, fast devsel, latency 0, IRQ 321
I/O ports at 1000 [size=256]
Memory at 20a8000000 (64-bit, non-prefetchable) [size=64K]
Capabilities:
Kernel driver in use: rtl88x2ce
Kernel modules: rtl8822ce
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 66
I/O behind bridge: [disabled]
Capabilities:
0004:01:00.0 Non-Volatile memory controller: Micron/Crucial Technology Device 540a (rev 01) (prog-if 02 [NVM Express])
Subsystem: Micron/Crucial Technology Device 5021
Memory at 2428000000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: nvme
@ubuntu:~$ sudo dmesg | grep pcieport
[ 8.075978] pcieport 0001:00:00.0: Adding to iommu group 9
[ 8.082548] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 8.089639] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 8.393427] pcieport 0004:00:00.0: Adding to iommu group 10
[ 8.400045] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 8.407275] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 9.902926] pcieport 0005:00:00.0: Adding to iommu group 11
[ 9.909662] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 9.916839] pcieport 0005:00:00.0: AER: enabled with IRQ 68
@ubuntu:~$ sudo dmesg | grep rtl88x2ce
[ 12.385644] rtl88x2ce 0001:01:00.0: Adding to iommu group 9
[ 12.386000] rtl88x2ce 0001:01:00.0: enabling device (0000 → 0003)
