I have been facing an issue for over 3 days now and I cannot find a solution.
I currently have a 32GB Jetson with the newest Jetpack version. Before you recommend re-flashing, I tried that 3 times.
Upon booting up the device, I am able to connect via ethernet with no issues. However, when trying to connect to a wifi network I get an error Error: Connection activation failed: (7) Secrets were required, but not provided.
I have tried using the GUI, nmtui, and nmcli. I have also disabled power management and reinstalled drivers found here GitHub - lwfinger/rtw88
Please advise - we need this device working. Having both ethernet + wifi working is critical for our use case .
Another thing ill add is that as soon as I boot up, I see the networks I want to connect to, then they disappear until I reboot. When im able to select the networks before they disappear, I get prompted to enter the password over and over
