i just installed a RT-kernel on my AGX Orin,
but i found there is no wi-fi option. The setting is like that:
After that, i used the folled code:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install iwlwifi-modules
sudo dmesg |grep iwlwifi
and the termial shows:
and meanwhile the setting finally has wifi option, but no adapter found.
It’s wired, when i used the primary kernel, the wifi works normal. But it failed for RT-kernel. could you help me to fix it?
We support jetson_multimedia_api and gstreamer. Please make sure you have checked the document:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/Multimedia.html
https://docs.nvidia.com/jetson/archives/r36.3/ApiReference/index.html
There are some examples in
Q: Is there any example of running RTSP streaming?
Q: Is there an example for running UDP streaming?
Q: I have a USB camera. How can I launch it on AGX Orin?
For further issues, please share a method to replicate the issue through gstreamer command, or either sample. We will set up developer kit and check.
Please enable the configs for a try:
Jetson/L4T/r36.3.x patches - eLinux.org
Enable AX210 WIFI module
thanks for the link. I have noticed that they have downloaded a backport from Linux Backports . As i’m using 5.15.148-rt-tegra kernel, i choosed backports-5.15.148-1.tar.xz. then i uesd these code from this link :
tar Jxfv backports-5.15.148-1.tar.xz.
cd backports-5.15.148-1
make defconfig-iwlwifi
make -j8
sudo make install
and
I add the following line to
/etc/modprobe.d/iwlwifi.conf
options iwlwifi 11n_disable=1
and , reboot OS.
But the wifi option still doesn’t appear.
By a way, when i input: lspci, there is
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1)
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0004:01:00.0 Non-Volatile memory controller: Silicon Motion, Inc. SM2263EN/SM2263XT SSD Controller (rev 03)
Does it means that the network card hardware is recognized by the system, but the driver may not be loaded or configured correctly?
We follow the steps to build/flash RT kernel to AGX Orin devkit and WIFI module works fine:
Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation
$ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.136-rt-tegra (danel@danel-HP-Compaq-6200-Pro-MT-PC) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU l
d (GNU Binutils) 2.38) #1 SMP PREEMPT_RT Thu Sep 19 09:48:56 CST 2024 ()
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
Please follow the steps one by one and check again.
system
Closed
December 3, 2024, 2:00pm
9
