AGX ORIN 64GB failed to Flash
I used SDK manager to flash the device and can’t flash the device, attachment is the log and the snapshot of the first error during installation. I am installing jetpack5.1.2 from a ubuntu machine with usb cable connected to the destination device.
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_AGX_Orin_64GB_2025-02-13_17-08-03.zip (211.1 KB)
17:08:17 ERROR: Flash Jetson Linux - flash: [ 0.1095 ] Error: Skip generating mem_bct because sdram_config is not defined
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1096 ] Copying signatures
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1102 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1133 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1134 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1134 ] Boot Rom communication
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1139 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1145 ] BR_CID: 0xE1012344705DF3406C00000014FE8240
17:08:17 INFO: Flash Jetson Linux - flash: [ 0.1407 ] Sending bct_br
17:08:22 ERROR: Flash Jetson Linux - flash: [ 0.1836 ] ERROR: might be timeout in USB write.
17:08:22 ERROR: Flash Jetson Linux - flash: Error: Return value 3
17:08:22 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
17:08:22 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed.
17:08:22 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/security/.nvsdkm/replays/scripts/JetPack_5.1.2_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: — Error: Reading board information failed.
17:08:22 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
17:08:22 INFO: Flash Jetson Linux - flash: [host] [ 12.23 MB used. Disk Avail on Partition /dev/nvme0n1p2: 425.01 GB ]
17:08:22 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 6s ]
17:08:22 ERROR: command error code: 11
17:08:22 ERROR: Flash Jetson Linux - flash: command terminated with error
17:08:22 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
17:08:22 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
17:08:22 SUMMARY: Multimedia API - target: Depends on failed component
17:08:22 SUMMARY: TensorRT on Target - target: Depends on failed component
17:08:22 SUMMARY: TensorRT Runtime - target: Depends on failed component
17:08:22 SUMMARY: VPI on Target - target: Depends on failed component
17:08:22 SUMMARY: VPI Runtime - target: Depends on failed component
17:08:22 SUMMARY: CuPVA Runtime - target: Depends on failed component
17:08:22 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
17:08:22 SUMMARY: CUDA Runtime - target: Depends on failed component
17:08:22 SUMMARY: cuDNN on Target - target: Depends on failed component
17:08:22 SUMMARY: CuDNN Runtime - target: Depends on failed component
17:08:22 SUMMARY: OpenCV - target: Depends on failed component
Please check the quick start in developer guide and make sure you follow the steps one by one:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/IN/QuickStart.html
If the device still cannot be flashed/booted, please refer to the page to get uart log from the device:
https://elinux.org/Jetson/General_debug
If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Please try the below Q&A mentioned commands.
Also make sure the device in recovery mode.
You could refer to doc to check whether the device in recovery mode.
