Jetson AGX Orin devkit 64GB flashing issue with jetpack 5.1.1
Hi i’m using the sdk manager to flash a brand new Jetson AGX Orin developer kit and i keep on getting that installation failed . there are errors during the flashing process. I tried changing the usb that connects the jetson to the host machine but nothing is working
SDKM_logs_JetPack_5.1.1_(rev._1)Linux_for_Jetson_AGX_Orin[64GB_developer_kit_version]_2025-03-17_14-09-31.zip|attachment (295.7 KB)
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
please check
Hi
it worked
thanks
