Hello Dear Forum. I have a problem in installing Jetpack 5.0.2. The jetson is in recovery mode, but when NVIDIA SDK manager try to flash it, I got the errors.
This is the last logs with error messages:
07:14:04 SUMMARY: Compute Sanitizer - host: Install completed successfully.
07:14:08 ERROR: shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
07:14:39 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
07:17:05 SUMMARY: File System and OS - target_image: Install completed successfully.
07:17:55 ERROR: Flash Jetson AGX Orin - flash: [ 0.0228 ] ERROR: failed to read rcm_state
07:17:55 ERROR: Flash Jetson AGX Orin - flash: [ 0.1877 ] Error: Skip generating mem_bct because sdram_config is not defined
07:17:58 ERROR: Flash Jetson AGX Orin - flash: Error: missing dtbfile (/home/brimo/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0005-p3737-0000.dtb).
07:17:58 ERROR: Flash Jetson AGX Orin - flash: — Error: Reading board information failed.
07:17:58 ERROR: Flash Jetson AGX Orin - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_ORIN_WITH_OS_IMAGE_COMP.brimo.sh; [error]: — Error: Reading board information failed.
07:17:58 ERROR: Flash Jetson AGX Orin - flash: command terminated with error
07:17:58 SUMMARY: Flash Jetson AGX Orin - flash: First Error: Installation failed.
07:17:58 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
07:17:58 SUMMARY: BSP Patch - target: Depends on failed component
07:17:58 SUMMARY: Multimedia API - target: Depends on failed component
07:17:58 SUMMARY: TensorRT on Target - target: Depends on failed component
07:17:58 SUMMARY: VPI on Target - target: Depends on failed component
07:17:58 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
07:17:58 SUMMARY: cuDNN on Target - target: Depends on failed component
07:17:58 SUMMARY: OpenCV - target: Depends on failed component
07:17:58 SUMMARY: DateTime Target Setup - target: Depends on failed component
07:18:17 SUMMARY: CUDA on Host - host: Install completed successfully.
07:18:17 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
07:18:17 SUMMARY: NvSci - host: Install completed successfully.
07:18:17 SUMMARY: VPI on Host - host: Install completed successfully.
07:18:17 SUMMARY: Nsight Systems - host: Install completed successfully.
07:18:17 SUMMARY: Nsight Graphics - host: Install completed successfully.
07:18:17 SUMMARY: Nsight Compute - host: Install completed successfully.
07:18:17 SUMMARY: CUPTI - host: Install completed successfully.
07:18:17 SUMMARY: Compute Sanitizer - host: Install completed successfully.
07:18:21 ERROR: shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
07:18:49 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
07:21:07 SUMMARY: File System and OS - target_image: Install completed successfully.
07:21:20 ERROR: Flash Jetson AGX Orin - flash: [ 0.0217 ] ERROR: failed to read rcm_state
07:21:20 ERROR: Flash Jetson AGX Orin - flash: [ 0.1536 ] Error: Skip generating mem_bct because sdram_config is not defined
07:21:23 ERROR: Flash Jetson AGX Orin - flash: Error: missing dtbfile (/home/brimo/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0005-p3737-0000.dtb).
07:21:23 ERROR: Flash Jetson AGX Orin - flash: — Error: Reading board information failed.
07:21:23 ERROR: Flash Jetson AGX Orin - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_ORIN_WITH_OS_IMAGE_COMP.brimo.sh; [error]: — Error: Reading board information failed.
07:21:23 ERROR: Flash Jetson AGX Orin - flash: command terminated with error
07:21:23 SUMMARY: Flash Jetson AGX Orin - flash: First Error: Installation failed.
07:21:23 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
07:21:23 SUMMARY: BSP Patch - target: Depends on failed component
07:21:23 SUMMARY: Multimedia API - target: Depends on failed component
07:21:23 SUMMARY: TensorRT on Target - target: Depends on failed component
07:21:23 SUMMARY: VPI on Target - target: Depends on failed component
07:21:23 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
07:21:23 SUMMARY: cuDNN on Target - target: Depends on failed component
07:21:23 SUMMARY: OpenCV - target: Depends on failed component
07:21:23 SUMMARY: DateTime Target Setup - target: Depends on failed component
Previously I have successfully flashed it to Jetpack 6.0, but now I want to downgrade it to 5.02 to support realsense drivers , Could you please help me? Thanks!
