SDKManager Jetson Orin AGX 32GB flash failed
I faced a problem after agx orin jetpack update in itself (it does not boot and just the temperature goes high).
So, I’m flashing this by my desktop as the host machine using sdkmanager.
But the error occurs continuously.
Here’s my configurations and procedure.
I’m following the below site using JetPack 5.1.2
Host Machine: Ubuntu 18.04.6 LTS (x86_64)
Target Machine: AGX Orin 32GB Developer Kit
SDK Manager version: 2.0.0.11402 x86_64
Target JetPack: 5.1.2
Connector: C to USB connector(included in develop kit),
Connect port: (10) USB Type-C port** Also for flashing (UFP and DFP)
[Errors]
22:29:26 ERROR: Flash Jetson Linux - flash: [ 0.1356 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
22:29:26 ERROR: Flash Jetson Linux - flash: [ 0.1497 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:29:26 ERROR: Flash Jetson Linux - flash: [ 0.1505 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:29:31 ERROR: Flash Jetson Linux - flash: [ 0.5857 ] ERROR: might be timeout in USB write.
22:29:31 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed.
22:29:31 ERROR: Flash Jetson Linux - flash: command terminated with error
22:29:31 SUMMARY: DateTime Target Setup - target: Depends on failed component
[SUMMARY]
22:23:30 SUMMARY: CUDA on Host - host: Install completed successfully.
22:23:30 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
22:23:30 SUMMARY: NvSci - host: Install completed successfully.
22:23:30 SUMMARY: VPI on Host - host: Install completed successfully.
22:23:30 SUMMARY: Nsight Systems - host: Install completed successfully.
22:23:30 SUMMARY: Nsight Graphics - host: Install completed successfully.
22:23:30 SUMMARY: Nsight Compute - host: Install completed successfully.
22:23:30 SUMMARY: Nsight Perf SDK - host: Install completed successfully.
22:24:25 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
22:27:45 SUMMARY: File System and OS - target_image: Install completed successfully.
22:29:31 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
22:29:31 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
22:29:31 SUMMARY: Multimedia API - target: Depends on failed component
22:29:31 SUMMARY: TensorRT on Target - target: Depends on failed component
22:29:31 SUMMARY: TensorRT Runtime - target: Depends on failed component
22:29:31 SUMMARY: VPI on Target - target: Depends on failed component
22:29:31 SUMMARY: VPI Runtime - target: Depends on failed component
22:29:31 SUMMARY: CuPVA Runtime - target: Depends on failed component
22:29:31 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
22:29:31 SUMMARY: CUDA Runtime - target: Depends on failed component
22:29:31 SUMMARY: cuDNN on Target - target: Depends on failed component
22:29:31 SUMMARY: CuDNN Runtime - target: Depends on failed component
22:29:31 SUMMARY: OpenCV - target: Depends on failed component
22:29:31 SUMMARY: OpenCV Runtime - target: Depends on failed component
I tried several times by using Ubuntu20.04, and the problem occured, so I used another Ubuntu18.04 host, but same problem occurs.
I think the internet is not the problem.
Do you know how to solve it?
Thank you in advance.
Use the “EXPORT LOGS” button on your sdkmanager instead of copy and paste.
That log has full detail.
I have done that, and I have several log files. But I don’t get the exact cause of the error.
Which log file should be uploaded if I want help?
This is log file for flash jetson.
NV_L4T_FLASH_JETSON_LINUX_COMP.log (11.5 KB)
[   0.3268 ] Sending bct_br
Error: Return value 3
Please check this guide:
If you don’t know what to upload, upload them all as zip file.
Currently, please follow DaveYYY’s suggestion.
Thank you! I really appreciate that I could flash the jetson.
