SDKM_logs_JetPack_6.1_Linux_for_Jetson_AGX_Orin_[64GB_developer_kit_version]_2024-11-21_14-42-32.zip (130.7 KB)
Error information
ERROR: [ 0.0081 ] ERROR: failed to read rcm_state
15:44:49 ERROR: [ 0.0083 ] ERROR: failed to read rcm_state
15:44:53 ERROR: Flash Jetson Linux - flash: [ 0.0088 ] ERROR: failed to read rcm_state
15:44:57 ERROR: Flash Jetson Linux - flash: [ 0.0085 ] ERROR: failed to read rcm_state
15:00:30 ERROR: Flash Jetson Linux - flash: [ 5.0990 ] Error: try getting custinfo fail. Moving on
15:00:33 ERROR: Flash Jetson Linux - flash: gzip: /home/zmy/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
15:01:08 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.0573357 s, 1.2 GB/s
15:01:13 ERROR: Flash Jetson Linux - flash: /home/zmy/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
15:01:13 ERROR: Flash Jetson Linux - flash: /home/zmy/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
15:01:14 ERROR: Flash Jetson Linux - flash: [ 0.2766 ] ERROR: value 0x31 is out of range
15:01:14 ERROR: Flash Jetson Linux - flash: [ 0.2798 ] ERROR: value 0x31 is out of range
15:01:14 ERROR: Flash Jetson Linux - flash: [ 0.2799 ] ERROR: value 0x31 is out of range
15:01:14 ERROR: Flash Jetson Linux - flash: [ 0.2800 ] ERROR: value 0x31 is out of range
15:01:16 ERROR: Flash Jetson Linux - flash: [ 2.7847 ] ERROR: value 0x31 is out of range
15:01:16 ERROR: Flash Jetson Linux - flash: [ 2.7853 ] ERROR: value 0x31 is out of range
15:01:16 ERROR: Flash Jetson Linux - flash: [ 2.7854 ] ERROR: value 0x31 is out of range
15:26:25 ERROR: Flash Jetson Linux - flash: Error: Return value 8
15:26:25 ERROR: Flash Jetson Linux - flash: *** ERROR: flashing failed.
15:26:25 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/zmy/.nvsdkm/replays/scripts/JetPack_6.1_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: *** ERROR: flashing failed.
15:26:25 ERROR: command error code: 11
15:26:25 ERROR: Flash Jetson Linux - flash: command terminated with error
15:26:25 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
15:26:25 SUMMARY: Multimedia API - target: Depends on failed component
15:26:25 SUMMARY: TensorRT on Target - target: Depends on failed component
15:26:25 SUMMARY: TensorRT Runtime - target: Depends on failed component
15:26:25 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
15:26:25 SUMMARY: CUDA Runtime - target: Depends on failed component
15:26:25 SUMMARY: CuDNN on Target - target: Depends on failed component
15:26:25 SUMMARY: CuDNN Runtime - target: Depends on failed component
15:26:25 SUMMARY: OpenCV - target: Depends on failed component
15:26:25 SUMMARY: OpenCV Runtime - target: Depends on failed component
15:26:25 SUMMARY: VPI on Target - target: Depends on failed component
15:26:25 SUMMARY: VPI Runtime - target: Depends on failed component
15:26:25 SUMMARY: CuPVA Runtime - target: Depends on failed component
15:26:25 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
15:26:25 SUMMARY: Nsight Systems - target: Depends on failed component
15:26:25 SUMMARY: Nsight Graphics - target: Depends on failed component
15:26:25 SUMMARY: Gstreamer - target: Depends on failed component
15:26:25 SUMMARY: DLA Compiler - target: Depends on failed component
15:26:25 SUMMARY: DateTime Target Setup - target: Depends on failed componen
Host:ubuntu22.04
SDKManager:2.2.0
Jetpack:6.1
USB-A plug in host , type-C plug in AGX orin
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
I see the error log:
E> NV3P_SERVER: Failed to get address for br bct from nv3p helper.
Is your AGX orin the dev kit or the custom carrier board?
I changed the environments to:
Host:ubuntu20.04
SDKManager:1.9.3
Jetpack:5.1
and flashed successfully.
but I don’t know why it flashed successfully though so many errors occurred
ERROR: W: Some index files failed to download. They have been ignored, or old ones used instead.
17:01:29 ERROR: CuDNN Runtime - target: Download 'CuDNN Runtime' failure
17:01:29 ERROR: CuDNN Runtime - target: download failed
17:09:53 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
17:15:56 SUMMARY: File System and OS - target_image: Install completed successfully.
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.0297 ] ERROR: failed to read rcm_state
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1290 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1293 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1294 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1296 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1298 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1299 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1301 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1302 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1304 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1309 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1309 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1398 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1401 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1402 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1404 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1405 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1407 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1408 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1410 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1411 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
17:17:50 ERROR: Flash Jetson Linux - flash: [ 0.1413 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7598 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7599 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7600 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7601 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7602 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7859 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7862 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7864 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7866 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7868 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7870 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7873 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7875 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7878 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7880 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7883 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7885 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7887 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
17:18:47 ERROR: Flash Jetson Linux - flash: [ 2.7889 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
17:30:55 SUMMARY: Flash Jetson Linux - flash: Install completed successfully.
SDKM_logs_2024-11-22_19-14-42.zip (264.3 KB)
I would like to confirm whether the device is now booting normally or if any other issues occurs while using the AGX Orin. Based on the logs provided, it appears that the flashing process failed.
it can boot normally now. But why isn’t a browser in the ubuntu 22.04 and jetpack 6.0
You can install chromium by following command:
sudo apt update
sudo apt install chromium-browser
