Jetson Orin won't boot after flashing
I don’t know what is going on with this, it’s been working fine with the SDK flashing and now something isn’t working right. I’ve also never looked in the logs before but now it’s not working right I’ve been looking and it’s showing errors. I’m not sure if these are normal and were there before.
I just wanted a clean install of everything and now I’m a bit stuck. It seems to flash the device and then the device starts up, shows the nvidia boot splash screen and then the fan stops for a second, spins fast, slows down to normal and the screen turns off… then the SDK cannot connect again to finish the install.
I’ve filtered the log for errors, it’s part of the way through flashing again.
Any help would be really appreciated as it’s only about a month old. Its the ORIN 32GB standard developer board.
13:22:59 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0,000292223 s, 68,4 kB/s
13:23:06 SUMMARY: VPI on Host - host: Install completed successfully.
13:23:40 SUMMARY: Nsight Compute - host: Install completed successfully.
13:24:37 ERROR: Flash Jetson Linux - flash: 131072+0 records in
13:24:37 ERROR: Flash Jetson Linux - flash: 131072+0 records out
13:24:37 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0,495105 s, 136 MB/s
13:24:43 ERROR: Flash Jetson Linux - flash: /home/finn/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
13:24:43 ERROR: Flash Jetson Linux - flash: /home/finn/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8328 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8334 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8338 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8341 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8344 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8350 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8358 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8363 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8368 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8373 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8378 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8383 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8388 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
13:24:49 ERROR: Flash Jetson Linux - flash: [ 5.8392 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9632 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9639 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9644 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9650 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9655 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9661 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9667 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9672 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9677 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9682 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9687 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9692 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9696 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9700 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9938 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9944 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9949 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9954 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9958 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9964 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9969 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9973 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9978 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9984 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9989 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9994 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9999 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
13:24:51 ERROR: Flash Jetson Linux - flash: [ 7.9999 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
You may need to export full logs.
it looks like (thankfully) the curse of the post… now it seems to be working after 24 hours of failed flashes… would be great to know what was going wrong. Do you know what it means at boot when it says test key pressed or something, that was happening all the time but now seems to be gone… i haven’t changed anything though
happy to post logs but not sure how to do that, also this will be the first log where it looks like it’s worked - at least the im in ubuntu on the orin and ssh is working
That “test key pressed” thing does not matter.
It was there even in normal boot up case.
