Hello everyone,
I need help quickly! When I want to re-flash my Jetson because it keeps starting and shutting down again, I get the following error message:
16:50:14 ERROR: Flash Jetson Linux - flash: [ 13.0019 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
16:50:14 ERROR: Flash Jetson Linux - flash: [ 13.0021 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
16:50:14 ERROR: Flash Jetson Linux - flash: [ 13.0023 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
16:50:14 ERROR: Flash Jetson Linux - flash: [ 13.0024 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
16:50:15 ERROR: Flash Jetson Linux - flash: [ 14.1676 ] ERROR: value 0x31 is out of range
16:50:15 ERROR: Flash Jetson Linux - flash: [ 14.1682 ] ERROR: value 0x31 is out of range
16:50:15 ERROR: Flash Jetson Linux - flash: [ 14.1683 ] ERROR: value 0x31 is out of range
My approach is:
Put Jetson into recovery, with the right USB-C Ports
SDKM_logs_2024-04-21_16-51-01.zip (158.6 KB) -
SDK Manager: Select target, JetPack 5.1.3 and continue
The flashing stops after the half time and the Jetson starts and shuts down again in a loop, permanently.
I tried with the VM and host Ubuntu 18.04 and 20.04
I do not know how to continue :/
