My host machine is running ubuntu 18.04, and use sdkmanager1.8 to flash jetson-agx-orin-devkit.
I had the same situation when I flash. Refer to Cannot flash jetpack 5/L4T 34.1,but I use the original power supply, and also tested another 12V power supply.
Here is the flash error message.
19:40:03 INFO: File System and OS - target_image: Processing triggers for nvidia-l4t-kernel (5.10.65-tegra-34.1.0-20220406120854) ...
19:40:04 ERROR: File System and OS - target_image: /etc/kernel/postinst.d/apt-auto-removal:
19:40:04 ERROR: File System and OS - target_image: qemu: Unsupported syscall: 276
19:40:04 INFO: File System and OS - target_image: Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
19:40:04 INFO: File System and OS - target_image: Removing QEMU binary from rootfs
19:40:04 INFO: File System and OS - target_image: Removing stashed Debian packages from rootfs
19:40:04 INFO: File System and OS - target_image: L4T BSP package installation completed!
19:40:04 INFO: File System and OS - target_image: Disabling NetworkManager-wait-online.service
19:40:04 INFO: File System and OS - target_image: Disable the ondemand service by changing the runlevels to 'K'
19:40:04 INFO: File System and OS - target_image: Success!
19:40:04 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_T234_COMP Install took 2m9s ]
19:40:04 INFO: File System and OS - target_image: command finished successfully
19:40:04 SUMMARY: File System and OS - target_image: Install completed successfully.
19:41:31 ERROR: Can not find matching device in recovery mode.
19:41:31 DEBUG: running command < true >
19:41:31 INFO: command finished successfully
19:41:35 INFO: Flash Jetson AGX Orin - flash: Re-generating recovery ramdisk for recovery image...
19:41:35 INFO: Flash Jetson AGX Orin - flash: ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
19:41:35 ERROR: Flash Jetson AGX Orin - flash: 36137 blocks
19:41:35 ERROR: Flash Jetson AGX Orin - flash: gzip: /home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
19:41:36 INFO: Flash Jetson AGX Orin - flash: _BASE_KERNEL_VERSION=5.10.65-tegra
19:41:39 ERROR: Flash Jetson AGX Orin - flash: 52378 blocks
19:41:39 INFO: Flash Jetson AGX Orin - flash: Making Recovery image...
19:41:39 INFO: Flash Jetson AGX Orin - flash: copying recdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec)... done.
19:41:39 ERROR: Flash Jetson AGX Orin - flash: 20 bytes copied, 8.0058e-05 s, 250 kB/s
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing sosfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing xusbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing dcefile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/dce.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing psc_rf(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing mb1file(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing bpffile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: copying bpfdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3701-0000-3737-0000.dtb)... done.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing scefile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Copying nv_boot_control.conf to rootfs
19:41:39 INFO: Flash Jetson AGX Orin - flash: Skip generating system.img
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing tbcfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
19:41:39 ERROR: Flash Jetson AGX Orin - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.120568 s, 557 MB/s
19:41:44 INFO: Flash Jetson AGX Orin - flash: Sync'ing esp.img ... done.
19:41:44 INFO: Flash Jetson AGX Orin - flash: copying tbcdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)... done.
19:41:48 INFO: Flash Jetson AGX Orin - flash: Making Boot image... done.
19:41:48 INFO: Flash Jetson AGX Orin - flash: Re-generating recovery ramdisk for recovery image...
19:41:48 INFO: Flash Jetson AGX Orin - flash: ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
19:41:48 ERROR: Flash Jetson AGX Orin - flash: 36137 blocks
19:41:48 ERROR: Flash Jetson AGX Orin - flash: gzip: /home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
19:41:48 INFO: Flash Jetson AGX Orin - flash: _BASE_KERNEL_VERSION=5.10.65-tegra
19:41:51 ERROR: Flash Jetson AGX Orin - flash: 52378 blocks
19:41:51 INFO: Flash Jetson AGX Orin - flash: Making Recovery image...
19:41:51 INFO: Flash Jetson AGX Orin - flash: copying recdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec)... done.
19:41:51 ERROR: Flash Jetson AGX Orin - flash: 20 bytes copied, 9.6441e-05 s, 207 kB/s
19:41:51 INFO: Flash Jetson AGX Orin - flash: Existing xusbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
19:41:51 INFO: Flash Jetson AGX Orin - flash: Existing dcefile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/dce.bin) reused.
19:41:51 INFO: Flash Jetson AGX Orin - flash: Existing nvdecfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
19:41:51 INFO: Flash Jetson AGX Orin - flash: Existing mb2_rf(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpurf_t234.bin) reused.
19:41:51 INFO: Flash Jetson AGX Orin - flash: Existing mb1file(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
19:41:51 INFO: Flash Jetson AGX Orin - flash: Existing bpffile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
19:41:51 INFO: Flash Jetson AGX Orin - flash: copying bpfdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3701-0000-3737-0000.dtb)... done.
19:42:51 INFO: Flash Jetson AGX Orin - flash: Sync'ing system.img ... done.
19:43:11 INFO: Flash Jetson AGX Orin - flash: Converting RAW image to Sparse image... done.
19:43:11 INFO: Flash Jetson AGX Orin - flash: system.img built successfully.
19:43:11 INFO: Flash Jetson AGX Orin - flash: Existing tbcfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
19:43:13 ERROR: Flash Jetson AGX Orin - flash: 67108864 bytes (67 MB, 64 MiB) copied, 1.50984 s, 44.4 MB/s
19:44:36 INFO: Flash Jetson AGX Orin - flash: Sync'ing esp.img ... done.
19:44:36 INFO: Flash Jetson AGX Orin - flash: copying tbcdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)... done.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing flashapp(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing overlay_dtb(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-overlay-pcie.dtbo) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing overlay_dtb(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-audio-codec-rt5658-40pin.dtbo) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing overlay_dtb(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-a04-overlay.dtbo) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing overlay_dtb(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-dual-imx274-overlay.dtbo) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing overlay_dtb(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3331-overlay.dtbo) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing overlay_dtb(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3333-overlay.dtbo) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: Existing overlay_dtb(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-imx390-overlay.dtbo) reused.
19:44:37 INFO: Flash Jetson AGX Orin - flash: saving flash command in /home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
