Hello!
When I use sdkmanager-1.8, it shows that flash is successful, but Orin doesn’t work properly when I power, it shows that Input Signal Not Found. Here is the flash error log.
ErrorMsg.txt (10.2 KB)
19:41:35 INFO: Flash Jetson AGX Orin - flash: Re-generating recovery ramdisk for recovery image...
19:41:35 INFO: Flash Jetson AGX Orin - flash: ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
19:41:35 ERROR: Flash Jetson AGX Orin - flash: 36137 blocks
19:41:35 ERROR: Flash Jetson AGX Orin - flash: gzip: /home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
19:41:36 INFO: Flash Jetson AGX Orin - flash: _BASE_KERNEL_VERSION=5.10.65-tegra
19:41:39 ERROR: Flash Jetson AGX Orin - flash: 52378 blocks
19:41:39 INFO: Flash Jetson AGX Orin - flash: Making Recovery image...
19:41:39 INFO: Flash Jetson AGX Orin - flash: copying recdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec)... done.
19:41:39 ERROR: Flash Jetson AGX Orin - flash: 20 bytes copied, 8.0058e-05 s, 250 kB/s
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing sosfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing xusbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing dcefile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/dce.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing psc_rf(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing mb1file(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing bpffile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: copying bpfdtbfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3701-0000-3737-0000.dtb)... done.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing scefile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
19:41:39 INFO: Flash Jetson AGX Orin - flash: Copying nv_boot_control.conf to rootfs
19:41:39 INFO: Flash Jetson AGX Orin - flash: Skip generating system.img
19:41:39 INFO: Flash Jetson AGX Orin - flash: Existing tbcfile(/home/soulauh/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
19:41:39 ERROR: Flash Jetson AGX Orin - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.120568 s, 557 MB/s
19:41:44 INFO: Flash Jetson AGX Orin - flash: Sync'ing esp.img ... done.
19:41:44 INFO: Flash Jetson AGX Orin - flash: copying
