JetPack 5.1.1 Installation Failed with SDK Manager (Jetson Orin Nano Dev Kit)
Hello, I tried to install JetPack 5.1.1 on my Jetson Orin Nano Dev Kit using SDK Manager but the installation goes to fail whenever I try.
Ver. of SDK Manager: 1.9.3.10904
Ver. of Host PC: Ubuntu 20.04.5 LTS
It would be great if you give me any solution or idea.
And this is the error log I got.
22:50:54 SUMMARY: CUDA on Host - host: Install completed successfully.
22:50:54 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
22:50:54 SUMMARY: NvSci - host: Install completed successfully.
22:50:54 SUMMARY: VPI on Host - host: Install completed successfully.
22:50:54 SUMMARY: Nsight Systems - host: Install completed successfully.
22:50:54 SUMMARY: Nsight Graphics - host: Install completed successfully.
22:50:54 SUMMARY: Nsight Compute - host: Install completed successfully.
22:50:54 SUMMARY: CUPTI - host: Install completed successfully.
22:50:54 SUMMARY: Compute Sanitizer - host: Install completed successfully.
22:50:54 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
22:50:54 SUMMARY: File System and OS - target_image: Install completed successfully.
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.0298 ] ERROR: failed to read rcm_state
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1723 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1729 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1735 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1741 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1744 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1906 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1913 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1919 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1924 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1925 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
2:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.1926 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.2070 ] Error: Skip generating mem_bct because sdram_config is not defined
22:51:26 ERROR: Flash Jetson Linux - flash: [ 0.2071 ] Error: Skip generating mem_bct because sdram_config is not defined
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.0241 ] ERROR: failed to read rcm_state
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1568 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1572 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1574 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1576 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1579 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1582 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1583 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1756 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1761 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1764 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1767 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1770 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1771 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:31 ERROR: Flash Jetson Linux - flash: [ 0.1944 ] Error: Skip generating mem_bct because sdram_config is not defined
22:51:35 ERROR: Flash Jetson Linux - flash: 39726 blocks
22:51:35 ERROR: Flash Jetson Linux - flash: gzip: /home/soohwanlee/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
22:51:41 ERROR: Flash Jetson Linux - flash: 56174 blocks
22:51:41 ERROR: Flash Jetson Linux - flash: 20+0 records in
22:51:41 ERROR: Flash Jetson Linux - flash: 20+0 records out
22:51:41 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000288717 s, 69.3 kB/s
22:51:42 ERROR: Flash Jetson Linux - flash: 131072+0 records in
22:51:42 ERROR: Flash Jetson Linux - flash: 131072+0 records out
22:51:42 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.561306 s, 120 MB/s
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7400 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7404 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7406 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7408 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7410 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7413 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7415 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7417 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7419 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7422 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7424 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7426 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7428 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7430 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7432 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7434 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:51 ERROR: Flash Jetson Linux - flash: [ 2.7435 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5335 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5339 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5341 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5343 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5345 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5347 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5349 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5351 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5353 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5355 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5357 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5359 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5361 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5363 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5365 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5368 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5369 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5570 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5574 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5578 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5581 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5584 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5588 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5591 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5594 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5597 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5601 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5604 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5607 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5610 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5610 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5610 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5610 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:53 ERROR: Flash Jetson Linux - flash: [ 4.5610 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.0234 ] ERROR: failed to read rcm_state
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1451 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1455 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1458 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1462 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1465 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1469 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1473 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1475 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1648 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1653 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1657 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1660 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1663 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1667 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1670 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1673 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:51:55 ERROR: Flash Jetson Linux - flash: [ 0.1827 ] Error: Skip generating mem_bct because sdram_config is not defined
22:51:59 ERROR: Flash Jetson Linux - flash: 39726 blocks
22:51:59 ERROR: Flash Jetson Linux - flash: gzip: /home/soohwanlee/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
22:52:04 ERROR: Flash Jetson Linux - flash: 56174 blocks
22:52:05 ERROR: Flash Jetson Linux - flash: 20+0 records in
22:52:05 ERROR: Flash Jetson Linux - flash: 20+0 records out
22:52:05 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000635591 s, 31.5 kB/s
22:55:18 ERROR: Flash Jetson Linux - flash: 131072+0 records in
22:55:18 ERROR: Flash Jetson Linux - flash: 131072+0 records out
22:55:18 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 1.71088 s, 39.2 MB/s
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0002 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0005 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0007 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0009 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0012 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0014 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0016 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0018 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0020 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0022 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0024 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0026 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0029 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0031 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0033 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0034 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:55:27 ERROR: Flash Jetson Linux - flash: [ 3.0036 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5184 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5189 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5192 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5196 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5199 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5203 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5207 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5210 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5213 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5216 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5219 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5222 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5226 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5229 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5232 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5235 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5238 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5650 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5657 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5663 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5668 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5674 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5680 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5686 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5691 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5697 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:55:28 ERROR: Flash Jetson Linux - flash: [ 3.5701 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:55:31 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 10000
22:55:32 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 20000
22:55:32 ERROR: Flash Jetson Linux - flash: oint 30000
22:55:36 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 40000
22:55:42 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 50000
22:55:43 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 60000
22:55:44 ERROR: Flash Jetson Linux - flash: tar: Write checkp
22:55:44 ERROR: Flash Jetson Linux - flash: oint 70000
22:55:44 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 80000
22:55:44 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 90000
22:55:44 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 100000
22:55:47 ERROR: Flash Jetson Linux - flash: tar: Write checkp
22:55:47 ERROR: Flash Jetson Linux - flash: oint 110000
22:55:50 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 120000
22:55:53 ERROR: Flash Jetson Linux - flash: tar: Write checkpo
22:55:53 ERROR: Flash Jetson Linux - flash: int 130000
22:55:54 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 140000
22:55:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoin
22:55:55 ERROR: Flash Jetson Linux - flash: t 150000
22:55:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 160000
22:55:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 170000
22:55:56 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 180000
22:55:57 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 190000
22:55:58 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 200000
22:55:59 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 210000
22:56:05 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 220000
22:56:06 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 230000
22:56:07 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 240000
22:56:07 ERROR: Flash Jetson Linux - flash: eckpoint 250000
22:56:07 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 260000
22:56:08 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 270000
22:56:08 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 280000
22:56:09 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 290000
22:56:10 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 300000
22:56:11 ERROR: Flash Jetson Linux - flash: tar: Write c
22:56:11 ERROR: Flash Jetson Linux - flash: heckpoint 310000
22:56:13 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 320000
22:56:19 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 330000
22:56:19 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 340000
22:56:19 ERROR: Flash Jetson Linux - flash: nt 350000
22:56:20 ERROR: Flash Jetson Linux - flash: tar: Write check
22:56:20 ERROR: Flash Jetson Linux - flash: point 360000
22:56:20 ERROR: Flash Jetson Linux - flash: tar: Write checkpo
22:56:20 ERROR: Flash Jetson Linux - flash: int 370000
22:56:20 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 380000
22:56:21 ERROR: Flash Jetson Linux - flash: tar: Write checkpoi
22:56:21 ERROR: Flash Jetson Linux - flash: nt 390000
22:56:22 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 400000
22:56:24 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 410000
22:56:25 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 420000
22:56:26 ERROR: Flash Jetson Linux - flash: tar: Write checkp
22:56:26 ERROR: Flash Jetson Linux - flash: oint 430000
22:56:31 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 440000
22:56:32 ERROR: Flash Jetson Linux - flash: tar: Write checkp
22:56:32 ERROR: Flash Jetson Linux - flash: oint 450000
22:56:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 460000
22:56:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpo
22:56:35 ERROR: Flash Jetson Linux - flash: int 470000
22:56:36 ERROR: Flash Jetson Linux - flash: tar: Write check
22:56:36 ERROR: Flash Jetson Linux - flash: point 480000
22:56:40 ERROR: Flash Jetson Linux - flash: tar: Write checkpoin
22:56:40 ERROR: Flash Jetson Linux - flash: t 490000
22:56:43 ERROR: Flash Jetson Linux - flash: tar: Write checkp
22:56:43 ERROR: Flash Jetson Linux - flash: oint 500000
22:56:46 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 510000
22:56:46 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
22:56:48 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
22:56:48 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 540000
22:56:48 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 550000
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.0507 ] ERROR: failed to read rcm_state
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2014 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2018 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2020 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2022 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2024 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2026 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2028 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2184 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2192 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2197 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2199 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2345 ] Error: Skip generating mem_bct because sdram_config is not defined
22:57:03 ERROR: Flash Jetson Linux - flash: [ 0.2346 ] Error: Skip generating mem_bct because sdram_config is not defined
22:57:07 ERROR: Flash Jetson Linux - flash: 39726 blocks
22:57:07 ERROR: Flash Jetson Linux - flash: gzip: /home/soohwanlee/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
22:57:14 ERROR: Flash Jetson Linux - flash: 56174 blocks
22:57:14 ERROR: Flash Jetson Linux - flash: 20+0 records in
22:57:14 ERROR: Flash Jetson Linux - flash: 20+0 records out
22:57:14 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.00125476 s, 15.9 kB/s
22:57:15 ERROR: Flash Jetson Linux - flash: 131072+0 records in
22:57:15 ERROR: Flash Jetson Linux - flash: 131072+0 records out
22:57:15 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.541406 s, 124 MB/s
22:57:21 ERROR: Flash Jetson Linux - flash: /home/soohwanlee/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
22:57:21 ERROR: Flash Jetson Linux - flash: /home/soohwanlee/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7061 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7065 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7067 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7070 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7072 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7074 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7076 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7078 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7080 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7082 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7084 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7086 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7089 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7091 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7093 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7095 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:57:24 ERROR: Flash Jetson Linux - flash: [ 2.7096 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5152 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5156 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5158 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5160 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5162 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5164 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5166 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5168 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5170 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5172 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5174 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5178 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5184 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5189 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5192 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5192 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5192 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5535 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5539 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5542 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5547 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5553 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5558 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5562 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5565 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5568 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5572 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5575 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5578 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5581 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5585 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5588 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5590 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
22:57:25 ERROR: Flash Jetson Linux - flash: [ 4.5593 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
22:57:29 ERROR: Flash Jetson Linux - flash: 56174 blocks
22:57:35 ERROR: Flash Jetson Linux - flash: 83099 blocks
22:58:28 ERROR: Flash Jetson Linux - flash: Error: Invalid argument during seek for read on /dev/mmcblk1
22:58:28 ERROR: Flash Jetson Linux - flash: [ 3]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
22:58:29 ERROR: Flash Jetson Linux - flash: command terminated with error
22:58:29 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
22:58:29 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
22:58:29 SUMMARY: Multimedia API - target: Depends on failed component
22:58:29 SUMMARY: TensorRT on Target - target: Depends on failed component
22:58:29 SUMMARY: TensorRT Runtime - target: Depends on failed component
22:58:29 SUMMARY: VPI on Target - target: Depends on failed component
22:58:29 SUMMARY: VPI Runtime - target: Depends on failed component
22:58:29 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
22:58:29 SUMMARY: CUDA Runtime - target: Depends on failed component
22:58:29 SUMMARY: cuDNN on Target - target: Depends on failed component
22:58:29 SUMMARY: CuDNN Runtime - target: Depends on failed component
22:58:29 SUMMARY: OpenCV - target: Depends on failed component
22:58:29 SUMMARY: OpenCV Runtime - target: Depends on failed component
22:58:29 SUMMARY: DateTime Target Setup - target: Depends on failed component
which storage device did you choose when installing the system?
Can the SD card be correctly detected when inserted to other devices/PCs?
For the storage, I used only SD card (32GB). In the middle of ‘STEP 02’ in SDK Manager running process,
  1. I inserted SD card to Jetson. At this moment, no power applied to Jetson. I just literally inserted it.
  2. And then I connected Jetson to the host PC.
    After that, I got a pop-up (screen below) that shows the Jetson is well detected. So actually I didn’t consider whether SD card is also correctly detected or not. I just assumed that SD card would be detected because the Jetson (which contains SD card) is detected.
Then can you check this?
Also export the full log from SDK Manager and attach it here.
Or use our SD card image:
If you don’t mind, can you explain how to check the detection condition of SD card?
(+ I’m re-trying to generate the full log. I will upload it soon.)
I mean, like, check if you can mount it on your host PC.
At least make sure it’s functioning well.
Yes it totally works well, recognized by host PC without any error, and empty 32GB storage.
And this is the log file.
GitHubDesktop-linux-3.0.0-linux2.deb (194.2 KB)
For the SD card image method, you can see how I tried to do and what problem I faced in the following link. This is my another post.
based on information from both of your posts, looks like the SD card is not detected by your device, and can you swap for another card for test?
It’d be better if you can prepare the UART log so we can do further check.
These are the logs. ‘serialLog.txt’ is the booting log of Jetson ‘without’ SD card, whereas ‘serialLog_sd.txt’ is the booting log of Jetson ‘with’ SD card.
(In this case, I used totally empty 32GB SD card.)
serialLog.txt (32.2 KB)
serialLog_sd.txt (32.4 KB)
I guessed the log comes out differently whether a SD card is equipped or not, so I made 2 cases, but it seems there is no difference. It would be great this information would help you to diagnose my current situation.
And for the SD Card, actually I ordered new 64GB SD card and it is still on the delivery process. Maybe I can test and notify the result at least 2 days later.
as the device can still enter UEFI, we can at least make sure the bootloader stuff was fine.
But as you got the same log with & without the SD card, you should really try for a different storage device.
The new SD card was delivered, so I was about to take SDK manager method again but I encountered this storage capacity issue. I don’t know why this happened.
Additionally I did the simple SD card image method with the new sd card again that I’ve already tried. But the result is same, showing ‘Attempting Direct Boot’.
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
