I am facing the same issue as JetPack 5.1.1 Installation Failed with SDK Manager (Jetson Orin Nano Dev Kit) .
Unable to flash from my Ubuntu 20.04.6 LTS to Jetson Orin board. I have herewith attached errors shown during flashing. I am not using an external SD card as my Orin has 64GB eMMC built-in.
Press EXPORT LOGS and attach the zip file for us to review.
Also some questions to confirm:
- Is AGX Orin a devkit or custom carrier board?
- Is Ubuntu running on a physical machine or virtual machine (e.g. WSL, VirtualBox, VMware)?
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_AGX_Orin_[64GB_developer_kit_version]_2024-12-23_14-24-44.zip (231.0 KB)
- Is AGX Orin a devkit or custom carrier board? - Please find below the specs of my Orin board. I believe its a devkit
- Is Ubuntu running on a physical machine or virtual machine (e.g. WSL, VirtualBox, VMware)? I am uring a physical Ubuntu laptop and not a VM.
I see some error logs
Error: Reading board information failed.
Have you put your device in recovery mode before the flashing process?
Please refer to this doc to verify whether the device in recovery mode.
