Can't successfully flash Jetson AGX Orin - Logs attached
Hello-
I have been trying to flash my Jetson AGX Orin 32GB dev kit using the nVidia SDK Manager (v1.9.3.10904) running on a host machine (not VM) that is running Ubuntu 18.04.6 LTS. Attempting to flas with target OS Jetpack version 5.1.1 (Rev. 1)
The Jetson is a Jetson AGX Orin 32GB Memory, 64GB eMMC, which I assume is referred to as a Jetson AGX Orin 32GB. When I connect the Jetson to my host, and launch the SDK manager, the SDK manager sees the target hardware and reports it as being a Jetson AGX Orin 32GB.
I have tried both the automatic and manual processes numerous times, all failed. The attached log zip files are from my last automatic attempt and last manual attempt.
Any assistance anyone can provide would be GREATLY appreciated, spent several hours wrestling with this to no avail, all very frustrating…
Thanks in advance,
Jim
Logs attached below:
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2023-07-11_12-18-15.zip (406.2 KB)
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2023-07-11_10-29-53.zip (124.2 KB)
did you dig into the error message?
I think it already explain the reason well:
ERROR xmllint not found! To install - please run: “sudo apt-get install libxml2-utils”
