Command Used" 30 sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
[ 9.8968 ] Using ramcode 0
[ 9.8968 ] Disabled BPMP dtb trim, using default dtb
[ 9.8968 ]
[ 9.9012 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 9.9053 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 9.9085 ] adding BCH for mem_rcm_aligned.bct
[ 9.9185 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 9.9188 ] Assuming zero filled SBK key
[ 9.9213 ] Warning: pub_key.key is not found
[ 9.9160 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 9.9189 ] Copying signatures
[ 9.9211 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 10.0155 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 10.0163 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 10.0164 ] Boot Rom communication
[ 10.0235 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Error: Return value 8
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Failed flashing t186ref.
SDK Manager error : Jetson board is in a bad state and cannot be recovered. Please manually put board to recovery mode again and retry… The Jetson target is in a bad state and cannot be flashed. Please manually put the target into recovery mode and then retry flashing.
