Sdkmanager Fail to flash Jetson AGX Orin
May I ask for your advice on this problem?
Target Platform: Jetson AGX Orin [64GB developer kit version]
Host: Ubuntu 18.04 installed in VirtualBox
Reference Link : Install Jetson Software with SDK Manager — SDK Manager
When I followed the steps in the above link to operate the SDK Manager, everything was normal.
However, when the flashing process started, I received a message saying “the target is in a bad state.”
I also attach the log as below. Could you please advise how to solve this issue?
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_AGX_Orin_[64GB_developer_kit_version]_2024-12-18_18-24-06 (1).zip (104.5 KB)
Thank you
Our host requirement is Ubuntu 20.04 (JP5.x/JP6.x) or 18.04 (JP4.x/JP5.x) running a physical machine not a virtual machine like VirtualBox.
If you have the PC, please try dual boot with ubuntu.
