Hi All,
We would like to use the AX210NGW on our customized board. I referred the below link to enable the AX210, but it keeps failing to connect.
I am attempting to get Intel’s AX210NGW wifi card working on some new Orin Nanos that I have. I know that this card isn’t officially supported at this time, but I have previously gotten it working on a different Orin Nano and was hoping someone might be able to help me figure out what I’m doing differently.
So far I have followed the processes described by my carrier board manufacturer (Jetpack , AX210 ). The driver install is adding Intel’s driver to /lib/firmware and deleting the iwlwifi-ty-a0-…
My code base is R35.5.0.
There is no any logs from the kernel. Please give me any suggestions. Thanks.
Michael
Please check this and give it a try:
Jetson/L4T/r36.3.x patches - eLinux.org
Enable AX210 WIFI module
Hi @DaneLLL
I tried it. The results as below:
Experiment 1 :
I found another solution – building the kernel from source. I added these to the arch/arm64/configs/defconfig
CONFIG_WLAN=y
CONFIG_WLAN_VENDOR_INTEL=y
CONFIG_IWLWIFI=m
CONFIG_IWLWIFI_LEDS=y
CONFIG_IWLDVM=m
CONFIG_IWLMVM=m
CONFIG_IWLWIFI_OPMODE_MODULAR=y
Result : I have already enabled it before.
Experiment 2 :
@dakejahl I have encountered the same problem.
So, I installed Wi-Fi driver from source code.
At first, I download backports-5.15.81-1.tar.xz from https://backports.wiki.kernel.org/index.php/Releases .
I installed backports-iwlwifi from source code.
tar Jxfv backports-5.15.81-1.tar.xz
cd backports-5.15.81-1
make defconfig-iwlwifi
make -j8
sudo make install
I add the following line to /etc/modprobe.d/iwlwifi.conf.
options iwlwifi 11n_disable=1
And, I reboot OS.
sudo reboot
Result : The AX210 can’t working after installing this version of backport.
Experiment 3:
The solution was to flash the new version of jetpack 6 tuned by Seeed (4th of July version)
Seeed have suggested an workaround, but in my case, had to be tuned more:
sudo rm /lib/modules/5.15.136-tegra/build
sudo ln -s /usr/src/linux-headers-5.15.136-tegra-ubuntu22.04_aarch64/3rdparty/canonical/linux-jammy/kernel-source/ /lib/modules/5.15.136-tegra/build
sudo apt install -y iwlwifi-modules
sudo apt update
sudo apt upgrade
sudo reboot
sudo modprobe iwlwifi
sudo lspci | grep Network
sudo…
Result: It can’t boot into Ubuntu after applying the modification.
Gorgo90
November 5, 2024, 12:56pm
5
I fixed it on my 5.1.2 with this patch:
You will lose the BT though because the patch fixes the wifi but the BT module will restart itself indefinitely. It must be disabled with the last sh script.
system
Closed
December 3, 2024, 1:49pm
7
