I am trying to setup an Intel AX210 on a custom carrier board. The default rootfs is used with L4T 36.4.3.
I installed backport-iwlwifi-dkms to get the missing drivers
sudo apt install backport-iwlwifi-dkms
The device show up with lspci:
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1)
0001:01:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
sudo dmesg | grep iwl
[ 10.572864] iwlwifi_compat: module verification failed: signature and/or required key missing - tainting kernel
[ 10.577880] Loading modules backported from iwlwifi
[ 10.577885] iwlwifi-stack-public:master:11510:0106cce5
[ 10.636179] iwlwifi 0001:01:00.0: Adding to iommu group 3
[ 10.636345] iwlwifi 0001:01:00.0: enabling device (0000 -> 0002)
[ 10.646213] iwlwifi 0001:01:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[ 10.646230] iwlwifi 0001:01:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
[ 72.911883] iwlwifi 0001:01:00.0: WRT: Invalid time point 28 for host command TLV
[ 72.911898] iwlwifi 0001:01:00.0: WRT: Failed to allocate TLV 0x1000007, ret -22, (ext=0)
[ 72.911905] iwlwifi 0001:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.41
[ 72.915640] iwlwifi 0001:01:00.0: loaded firmware version 86.fb5c9aeb.0 ty-a0-gf-a0-86.ucode op_mode iwlmvm
[ 72.944995] iwlwifi 0001:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 72.951672] iwlwifi 0001:01:00.0: reporting RF_KILL (radio disabled)
[ 73.117993] iwlwifi 0001:01:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 73.118023] iwlwifi 0001:01:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 73.118043] iwlwifi 0001:01:00.0: WFPM_AUTH_KEY_0: 0x90
[ 73.118063] iwlwifi 0001:01:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 73.119180] iwlwifi 0001:01:00.0: loaded PNVM version e28bb9d7
[ 73.135044] iwlwifi 0001:01:00.0: Detected RF GF, rfid=0x10d000
[ 73.205422] iwlwifi 0001:01:00.0: base HW address: dc:97:ba:b6:38:f7
[ 73.227751] iwlwifi 0001:01:00.0 wlP1p1s0: renamed from wlan0
nmcli shows the following:
wlP1p1s0: unavailable
"Intel 6 AX210/AX211/AX411 160MHz"
wifi (iwlwifi), DC:97:BA:B6:38:F7, sw disabled, hw disabled, hw, mtu 1500
nmcli device show
GENERAL.DEVICE: wlP1p1s0
GENERAL.TYPE: wifi
GENERAL.HWADDR: DC:97:BA:B6:38:F7
GENERAL.MTU: 1500
GENERAL.STATE: 20 (unavailable)
GENERAL.CONNECTION: --
GENERAL.CON-PATH: --
IP4.GATEWAY: --
IP6.GATEWAY: --
sudo ifconfig wlP1p1s0 up
SIOCSIFFLAGS: Operation not possible due to RF-kill
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
How can I fix that the wireless lan is hard blocked?
