AX210 on Jetpack 5.0.1 (5.10-65-tegra)
Installed an AX210 on Jetson NX using Jetpack 5.0.1 but I get no wifi and a flickering bluetooth icon in the top menu. According to Intel documentation, it says that kernels 5.10+ should support AX210.
Is there any other steps I can try or does Jetpack 5.0.1 not support the AX210 wifi module?
I can detect a Intel device via lspci which reveals.
"Intel Corporation Device 2725 (rev 1a)
Capabilities:
We haven’t try that module, may other developers help to share experiences.
@user137691
Pls have a try with the driver/firmware provied here.
It should be ok to work on Jetson.
Hi, I have followed the instructions according to the website to minor levels of success.
Following the instructions on the intel website, I downloaded the relevant driver for the Intel® Wi-Fi 6 AX210 160MHz 5.10+ [iwlwifi-ty-59.601f3a66.0.tgz].
Downloaded the .tgz, unzippeed it and copied it in /lib/firmware directory as instructed.
After rebooting, I still cannot get wifi working and the bluetooth module is consistently intermittently detectable and not.
the firmware/ucode for wifi driver is detectable via the command “modinfo iwlwifi”.
Is it possible that the kernel used does not support/not compiled with the functionality to use the driver?
Yes, as mentioned previously - we haven’t try that module, we don’t kown if any issue work on current ARM64 kernel
