Does Jetpack4.6.4(Kernel 4.9.337-tegra) support Intel AX210 Wireless Adapters?
Ubuntu version 18.04.
I have tried Intel iwlwifi driver and iwlwifi-ty-a0-gf-a0-59.ucode firmware, But doesn’t work.
It would need a driver specific to the hardware (I don’t know which driver). Is the driver listed here?
https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html
If you know the driver exists at or earlier than 4.9.337, then you could compile the kernel module and copy it as an ordinary file to the correct location. The trick is that (A) you need to know the kernel config name, and then (B) you have to compile it using a config otherwise matching the running kernel. That makes a file copy to install trivial.
