AX210 Driver Issue
I am attempting to get Intel’s AX210NGW wifi card working on some new Orin Nanos that I have. I know that this card isn’t officially supported at this time, but I have previously gotten it working on a different Orin Nano and was hoping someone might be able to help me figure out what I’m doing differently.
So far I have followed the processes described by my carrier board manufacturer (Jetpack, AX210). The driver install is adding Intel’s driver to /lib/firmware and deleting the iwlwifi-ty-a0-gf-a0.pnvm file. I have also tried directly downloading the driver file from Intel’s website. I have seen this process mentioned a few times on different sites/threads, but haven’t found anything clearly tied to my situation.
I can see the WiFi card with both nmcli and lspci. From what I have found so far, dmesg shows the iwlwifi driver isn’t loading correctly (grep’d log attached). The NetworkManager and wpa_supplicant services are both reporting issues related to wlan0 as well. I can provide additional logs, but am not sure which would be useful and information about different settings (I have gone through enough things I can’t recall them all).
I have access to the Orin that I have previously setup the AX210 on and it is still able to connect to load and connect to networks, so I can check for settings differences between the different boards.
If anyone has any advice, I would greatly appreciate it!
dmesg.txt (138.2 KB)
please refer to this post as some other user provide the patches for this card.
this is not the best way
best way is inculde this patch in next update so there is no more disscation
