Intel BE200 Support on Jetson Orin NX
I found this thread
and basically have the same question: How can I use Wifi 7 with an Intel BE200 Wifi card on a Jetson Orin NX?
I am asking the question again as it is marked as solved in the original thread, but the answer is very unspecific and I did not manage to get it work based on the instructions I found. Could someone please give clearer instructions of what I need to do?
Setup:
Hardware: Boson Carrier board with Jetson Orin NX
Software: Jetpack 6.0 with kernel 5.15.136-tegra
OS: Ubuntu 22.04 LTS
What I have tried:
  1. From Jetpack 6 Wifi slow startup with backport-iwlwifi-dkms - #13 by dakejahl it says that you should build with some kernel options, but these are already set in the currently running one.
  2. From Jetpack 6 Wifi slow startup with backport-iwlwifi-dkms - #9 by dandelion1124 I chose the nearest backport-iwlwifi release (backports-5.15.153-1) and while I could install it, it didn’t support the Wifi card. Trying with backport-6.1.97-1 did not compile.
  3. Orin NX 16GB wifi problem - #12 by viorel.gheorghe kind of worked, but I do not get Wifi 7 speeds, instead it defaults to a older/slower wifi standard. I get from dmesg
[    9.304115] Loading modules backported from iwlwifi
[    9.304121] iwlwifi-stack-public:master:11510:0106cce5
[    9.314219] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[    9.315530] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[    9.317116] tegra-xusb 3610000.usb: Adding to iommu group 49
[    9.320297] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[    9.320562] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[    9.321628] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[    9.323583] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.327775] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.328987] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    9.335440] Intel(R) Wireless WiFi driver for Linux
[    9.335913]  usb3: Requested PHY is disabled
[    9.352427] CAN device driver interface
[    9.360363] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[    9.368137] iwlwifi 0001:03:00.0: Adding to iommu group 2
[    9.369063] iwlwifi 0001:03:00.0: enabling device (0000 -> 0002)
[    9.378748] thermal-trip-event cpu-throttle-alert: cooling device registered.
[    9.381662] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    9.381673] tegra-xusb 3610000.usb: xHCI Host Controller
[    9.384903] iwlwifi 0001:03:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
[    9.384989] iwlwifi 0001:03:00.0: PCI dev 272b/00f4, rev=0x472, rfid=0x112200
[    9.385758] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    9.386782] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    9.386814] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[    9.387027] tegra-xusb 3610000.usb: xHCI Host Controller
[    9.387036] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    9.387044] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    9.387735] TT CAN feature is not supported
[    9.388416] 	 Message RAM Configuration
               	| base addr   |0x0c312000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
               	| mram size   |0x00001000|
# and later
[   70.629710] iwlwifi 0001:03:00.0: WRT: Invalid time point 28 for host command TLV
[   70.629722] iwlwifi 0001:03:00.0: WRT: Failed to allocate TLV 0x1000007, ret -22, (ext=0)
[   70.629730] iwlwifi 0001:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.125
[   70.635032] iwlwifi 0001:03:00.0: loaded firmware version 86.fb5c9aeb.0 gl-c0-fm-c0-86.ucode op_mode iwlmvm
[   70.662707] iwlwifi 0001:03:00.0: Detected Intel(R) TBD Bz device, REV=0x472
[   70.949168] iwlwifi 0001:03:00.0: loaded PNVM version f0bea5fc
[   71.059958] iwlwifi 0001:03:00.0: base HW address: 44:a3:bb:8d:9a:6e
[   71.059992] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.059995] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.561231] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.561243] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.564033] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.564046] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.564053] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.564059] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.564065] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.564072] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   71.564078] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   75.402891] wlan0: authenticate with 9a:2a:6f:30:02:ef (local address=44:a3:bb:8d:9a:6e)
[   75.403233] wlan0: send auth to 9a:2a:6f:30:02:ef (try 1/3)
[   75.444716] wlan0: authenticate with 9a:2a:6f:30:02:ef (local address=44:a3:bb:8d:9a:6e)
[   75.444727] wlan0: send auth to 9a:2a:6f:30:02:ef (try 1/3)
[   75.457844] wlan0: authenticated
[   75.459048] wlan0: associate with 9a:2a:6f:30:02:ef (try 1/3)
[   75.472565] wlan0: RX AssocResp from 9a:2a:6f:30:02:ef (capab=0x1111 status=0 aid=2)
[   75.475796] wlan0: associated
[   75.511398] wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by 9a:2a:6f:30:02:ef
[   75.531454] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
I’d be glad about any tips for how to proceed.
We would suggest consult with vendor for support. Or would need other users to share experience.
Or you may consider the module listed in
Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits
