Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits
With increasing demand for developers who try to use Wi-Fi 6/6E/7 modules and unable to use them due to technical challenges with integration. We worked with the partners and came up with a list of Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits by our partners for your reference:
Partner Partner Name / Module Provider Module Part Number Connectivity Module Form Factor Interfaces Supported Link to Module Page Link to Drivers and Installation Instructions Link to Buy Product
Infineon Murata LBEE5XV2EA-802 Wi-Fi 6E 22 x 30 x 1.5 SDIO, PCIe 2EA M.2 Module - Embedded Artists 2EA M.2 Module - Embedded Artists 2EA M.2 Module - Embedded Artists
Infineon Ezurio 453-00119 Wi-Fi 6E 22 x 30 x 2.7 SDIO, PCIe Sona™ IF573 - WiFi 6E + Bluetooth 5.4 Module - Infineon CYW55573 | Ezurio Sona™ IF573 - WiFi 6E + Bluetooth 5.4 Module - Infineon CYW55573 | Ezurio Sona™ IF573 - WiFi 6E + Bluetooth 5.4 Module - Infineon CYW55573 | Ezurio
Infineon Ezurio 453-00120 Wi-Fi 6E 22 x 30 x 2.7 SDIO, PCIe Sona™ IF573 - WiFi 6E + Bluetooth 5.4 Module - Infineon CYW55573 | Ezurio Sona™ IF573 - WiFi 6E + Bluetooth 5.4 Module - Infineon CYW55573 | Ezurio Sona™ IF573 - WiFi 6E + Bluetooth 5.4 Module - Infineon CYW55573 | Ezurio
Infineon Azurewave AW-XB583MA-PUR Wi-Fi 6E 22 x 30 x 2.06 PCIe https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html
Infineon Azurewave AW-XB583MA-SUR Wi-Fi 6E 22 x 30 x 2.06 SDIO https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html
Infineon Azurewave AW-XB327MA-PUR Wi-Fi 6 22 x 30 x 2.06 PCIe https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html
Infineon Azurewave AW-XB327MA-SUR Wi-Fi 6 22 x 30 x 2.06 SDIO https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html
Infineon Azurewave AW-XB325MA-PUR Wi-Fi 6E 22 x 30 x 2.06 PCIe https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html
Infineon Azurewave AW-XB325MA-SUR Wi-Fi 6E 22 x 30 x 2.06 SDIO https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html
Infineon Murata LBEE5XV1XA-540 Wi-Fi 5 22 x 30 x 1.5 PCIe 1XA M.2 Module - Embedded Artists 1XA M.2 Module - Embedded Artists 1XA M.2 Module - Embedded Artists
Infineon Azurewave AW-CB511NF Wi-Fi 5 22 x 30 x 2.25 PCIe https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html https://www.azurewave.com/wireless-modules-infineon.html
Infineon Quectel FC80A Wi-Fi 5 13 x 15 x 2.2 SDIO Wi-Fi & Bluetooth FC80A | Quectel Wi-Fi & Bluetooth FC80A | Quectel Wi-Fi & Bluetooth FC80A | Quectel
Infineon Murata LBEE5XV2BZ-883 Wi-Fi 5 22 x 30 x 1.5 SDIO 2BZ M.2 Module - Embedded Artists 2BZ M.2 Module - Embedded Artists 2BZ M.2 Module - Embedded Artists
Telit Telit Cinterion FN980 4G/5G M.2 Key B USB FN980/FN980m | Telit Cinterion Telit Cinterion Download Zone - Login Where to Buy | Telit Cinterion
Telit Telit Cinterion FN990A40 4G/5G M.2 Key B USB Telit FN990Axx Enable the Next Generation of 5G Data Cards Telit Cinterion Download Zone - Login Where to Buy | Telit Cinterion
Telit Telit Cinterion FN990A28 4G/5G M.2 Key B USB Telit FN990Axx Enable the Next Generation of 5G Data Cards Telit Cinterion Download Zone - Login Where to Buy | Telit Cinterion
Telit Telit Cinterion FN990A40-HP 4G/5G M.2 Key B USB Telit FN990Axx Enable the Next Generation of 5G Data Cards Telit Cinterion Download Zone - Login Where to Buy | Telit Cinterion
Telit Telit Cinterion FN990A28-HP 4G/5G M.2 Key B USB Telit FN990Axx Enable the Next Generation of 5G Data Cards Telit Cinterion Download Zone - Login Where to Buy | Telit Cinterion
any wifi 7?
Good morning:
We were unable to get the Murata LBEE5XV2EA-802 Wifi 6E card to work on the Jetson Orin (as it comes from the factory with Ubuntu 20.04 with the 5.10.120-tegra kernel).
From this same web page we have navigated to Murata Community → ​Quick Start Guide → Murata Wi-Fi Solution for Jetson Linux Quick Start Guide (PDF), and we have observed that there is no manual for Jetson Orin but there is such a manual for Jetson Xavier.
Even so, following the same logic of the manual (but without generating a Linux image for the Jetson since the Orin comes with Ubuntu 20.04 installed from the factory) we have proceeded to install the driver. The links to the driver that come in the manual are old and now Murata offers its drivers from GitHub - murata-wireless/cyw-fmac: Cypress' backported "fmac" driver enabling Murata's Wi-Fi/Bluetooth modules. For support, post questions to: https://community.murata.com. We have downloaded, compiled, installed and loaded them in the kernel boot but the operating system that comes by default with the Jetson Orin does not see the Wifi card.
The driver loading is correct (even rewriting the cfg80211 module that comes with the original kernel as indicated in the manual) whether we do it manually or if these modules are loaded at the start of the operating system. However, the operating system does not see the Murata wifi card.
From this same web page you indicate that “modules that have been validated with AGX Orin devkits by our partners for your reference” so we ask you to tell us how to proceed to be able to make the Murata card that appears first on your list works.
I have continued to work on this matter and following your website Install Ubuntu on NVIDIA Jetson | Ubuntu → Ubuntu 22.04 for NVIDIA Jetson Orin Instructions v1.2, I have downloaded and installed the latest firmware on the Jetson Orin. However, using this method, I have been unable to install the Ubuntu 22.04 operating system.
Therefore, I have used your SDK Manager tool and I have been able to install the Ubuntu 22.04 operating system and the Jetson Runtime Components. Once the operating system has started, I have updated it until there are no more updates in the queue. However, the operating system still does not see the Murata WiFi card.
The only thing I can think of is compiling a new kernel, but I’m reading that this process is not trivial since their “tegra” kernels do not correspond to the standard kernel numbering and I can only recompile the installed kernel o kernels from your archive. Here Jetson Linux Archive | NVIDIA Developer I can see that their latest kernel version (36.4) corresponds to Jetpack 6.1, which is the version I have installed. That is, there are no more modern “tegra” kernels than the current one I have installed. If I’m wrong, please correct me and tell me how to proceed.
Receive my greetings and my thanks.
Hi adpozuelo
Here’s a post from our friends at Infineon, showing how they brought up the 2EA module on Jetpack6.2
AGX Orin+H2-PCIE Jetpack 6.2SDK (Jetson Linux 36.4.3)Fmac.pdf (747.6 KB)
Would someone be willing to create a .deb package using that post? Similar to what was done by Infineon in the past: GitHub - neilch0811/Infineon-AIROC-Wi-Fi-Nvidia-Release
I have a 453-00120 module and using the basic brcmfmac in Jetpack 6.1 results in a dmesg: brcmfmac: brcmf_chip_tcm_rambase: unknown chip: BCM55560/2, and that post indicates a successful dmesg output should be: brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac55572-pcie for chip BCM55560/2
I expect this same driver would work for the 2EALBEE5XV2EA-802 WiFi card too.
Edit: Was able to install a working driver with:
git clone https://github.com/Infineon/ifx-backports.git
cd ifx-backports/v6.1.97-backports
nano backport-include/linux/timer.h # modify based on post
make KLIB=/lib/modules/$(uname -r)/build KLIB_BUILD=/lib/modules/$(uname -r)/build defconfig-brcmfmac
make KLIB=/lib/modules/$(uname -r)/build KLIB_BUILD=/lib/modules/$(uname -r)/build modules -j$(nproc)
sudo make modules_install
sudo depmod -a
sudo reboot
But speeds appear to be WiFi 5, and vary drastically:
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec  10.9 MBytes  91.1 Mbits/sec
[  5]   1.00-2.00   sec  7.56 MBytes  63.4 Mbits/sec
[  5]   2.00-3.00   sec  8.09 MBytes  67.9 Mbits/sec
[  5]   3.00-4.00   sec  24.0 MBytes   202 Mbits/sec
[  5]   4.00-5.00   sec  31.2 MBytes   262 Mbits/sec
[  5]   5.00-6.00   sec  27.0 MBytes   227 Mbits/sec
[  5]   6.00-7.00   sec  22.1 MBytes   185 Mbits/sec
[  5]   7.00-8.00   sec  27.7 MBytes   233 Mbits/sec
[  5]   8.00-9.00   sec  29.8 MBytes   250 Mbits/sec
[  5]   9.00-10.00  sec  31.1 MBytes   261 Mbits/sec
[  5]  10.00-11.00  sec  31.7 MBytes   266 Mbits/sec
[  5]  11.00-12.00  sec  27.2 MBytes   228 Mbits/sec
[  5]  12.00-13.00  sec  27.9 MBytes   234 Mbits/sec
[  5]  13.00-14.00  sec  12.8 MBytes   107 Mbits/sec
[  5]  14.00-15.00  sec  1.92 MBytes  16.1 Mbits/sec
[  5]  15.00-16.00  sec  5.82 MBytes  48.8 Mbits/sec
[  5]  16.00-17.00  sec  8.56 MBytes  71.8 Mbits/sec
[  5]  17.00-18.00  sec  24.0 MBytes   201 Mbits/sec
[  5]  18.00-19.00  sec  20.7 MBytes   174 Mbits/sec
[  5]  19.00-20.00  sec  22.7 MBytes   190 Mbits/sec
[  5]  20.00-21.00  sec  20.0 MBytes   168 Mbits/sec
[  5]  21.00-22.00  sec  23.9 MBytes   200 Mbits/sec
[  5]  22.00-23.00  sec  22.7 MBytes   190 Mbits/sec
[  5]  23.00-24.00  sec  26.2 MBytes   219 Mbits/sec
[  5]  24.00-25.00  sec  31.7 MBytes   266 Mbits/sec
[  5]  25.00-26.00  sec  29.1 MBytes   244 Mbits/sec
[  5]  26.00-27.00  sec  30.6 MBytes   257 Mbits/sec
[  5]  27.00-28.00  sec  5.71 MBytes  47.9 Mbits/sec
[  5]  28.00-29.00  sec  7.52 MBytes  63.1 Mbits/sec
[  5]  29.00-30.00  sec  4.01 MBytes  33.6 Mbits/sec
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-30.64  sec   605 MBytes   165 Mbits/sec  214             sender
[  5]   0.00-30.00  sec   604 MBytes   169 Mbits/sec                  receiver
Hi Tom
How do I install the driver for AW-CB511NF module? Can I refer to this document to install the WiFi driver?Or could you provide a similar document guiding me on how to install the driver for AW-CB511NF module?
I’m really looking forward to your reply and truly appreciate your help.
Hey there,
This is Emmanuel from Intel Wifi Linux team.
We’d love to help anyone bringing up Intel wifi devices on the Jetson systems. Our devices support Wifi 6E and Wifi 7.
Our devices are supported natively on Linux and all you need is to enable the driver (IWLWIFI / IWLMVM / IWLMLD) in the linux kernel and put the right firmware file (that you can take from here). The kernel version does matter though:
AX210 is supported natively starting from 5.15
BE200 is supported starting from 6.5
If you need to run those devices on older kernels, you need to use backport and we can help with that.
Most important:
If you have any issues or difficulty, you can reach out to me: emmanuel.grumbach@intel.com.
We plan to start integrating our devices on the Jetson systems internally and we’ll share exact steps.
Hey,
my own experience - I have AX210 installed for wifi:
I’m using 5.15 / Ubuntu 22.04 provided by nVidia as a “recovery OS” if main OS goes wrong (modified kernel config to enable AX210 as mentioned) - but have to add additional config to disable Wifi 6. Since this is just a recovery OS I didn’t investigate further.
options iwlwifi disable_11ax=Y
options iwlwifi power_save=0
options iwlmvm power_scheme=1
However on my main OS I upgraded to 6.8 (or 6.12) kernel / Ubuntu 24.04 and then there’s no problem with Wifi 6/6E.
Glad to know!
Thanks for sharing!
note that:
is just a no-op. It is harmless and pointless.
disables power management meaning that you pull more power.
Hello, is there a bluetooth list too somewhere? Or instructions how to enable it for BCM55560 ?
Hi @emmanuel.grumbach do both backported AX210 & BE200 work in AP&Hotspot mode too? What about not backported? I guess the JP 7.2 will have Kernel >6.5 so backporting is not needed there…
I got two Intel BE200s and managed one of them working with Orin Nano JP6.2 with backport drivers, but 6GHz is low power, NO IR, so I need some WiFi 7 router/AP to properly test speeds.
Oopps.. I’m sorry - somehow I wasn’t notified by mail about your post.
Still new here ..
Sorry for the delay.
We support AP / hotspot but there are regulatory constraints.
6.5 does support BE200 but many many bugfixes were merged in newer kernels. The newer kernels support newer firmware versions that includes tons of fixes.
For a POC, you can go with the in-tree driver, but our recommendation is still to take the backport driver to get a newer version of the driver / firmware.
Were you able to make the BE200 work on 6GHz in station mode? We typically require BIOS configuration to use 6GHz.
Not sure exactly what you’re trying to build, but feel free to reach out if you need help.
I got WiFi 7 AP and 10G switch to test and:
BE200:
iperf3 -c -P 16 -t 30 -Z -R
[SUM] 0.00-30.01 sec 7.79 GBytes 2.23 Gbits/sec 9732 sender
[SUM] 0.00-30.00 sec 7.75 GBytes 2.22 Gbits/sec receiver
[SUM] 0.00-30.00 sec 2.51 GBytes 720 Mbits/sec 2 sender
[SUM] 0.00-30.01 sec 2.48 GBytes 709 Mbits/sec receiver
old card:
[SUM] 0.00-30.00 sec 2.34 GBytes 670 Mbits/sec 1946 sender
[SUM] 0.00-30.00 sec 2.23 GBytes 640 Mbits/sec receiver
[SUM] 0.00-30.00 sec 1.88 GBytes 539 Mbits/sec 0 sender
[SUM] 0.00-30.02 sec 1.85 GBytes 528 Mbits/sec receiver
also with UDP, jitter of BE200 is on average 0.054 ms while old card is 0.273 ms
My usecase is having robot indoor and stream data while developing, second use case was to switch to hotspot when having robot outdoor but BE200 apparently doesn’t use 6G band in this case.
Still, 2.2Gbps vs. 670Mbps on download is pretty good. I guess I was more interested in streaming data from Jetson for visualization, which is ~200Mbps higher than older card.
