Hello, I have seen here
that your product works on NVIDIA ORIN but I can’t make it works. I’ve tried to install using your instructions
following links from NVIDIA forum but it doen’t work on ORIN.
Please share more information. So you have this module:
Infineon Murata LBEE5XV2EA-802
And try to enable it on AGX Orin developer kit by following the guidance. It is not enabled. Do we understand it correctly?
Please also share which Jetpack version you are using. The latest version is Jetpack 6.2.
