I am experiencing an extremely odd issue with our Jetson Orin, we often disconnect and reconnect our robot to a switch, but on disconnecting the ethernet and reconnecting it it is extremely slow to reconnect and sometimes won’t even reconnect till we connect it to a different switch or router. I’ve had this issue with three different switches so I don’t think its the switch. It’s very critical that we are able to ssh as quickly as possible when re-attaching our tether, so really hoping we can solve this. We have a Jetson xavier on the exact same network and it is not experiencing this issue, I did a brand new L4T install just incase, and this did not help.
nvidia@ubuntu:~$ sudo dmesg | grep nvether
[sudo] password for nvidia:
[ 12.954871] nvethernet 6810000.ethernet: Adding to iommu group 52
[ 12.961473] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 12.969638] nvethernet 6810000.ethernet: failed to read MDIO address
[ 12.976179] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 12.983103] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 13.381226] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:7d:e5:20
[ 13.389485] nvethernet 6810000.ethernet: Macsec not enabled
[ 13.395221] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 13.406190] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 21.726892] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 43.227662] nvethernet 6810000.ethernet eth0: Link is Down
[ 47.326362] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 63.707653] nvethernet 6810000.ethernet eth0: Link is Down
[ 96.478458] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 105.692204] nvethernet 6810000.ethernet eth0: Link is Down
[ 129.246681] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:70:79:82:4d txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1466
inet 10.42.43.116 netmask 255.255.255.0 broadcast 10.42.43.255
inet6 fe80::bb37:9756:7480:50d prefixlen 64 scopeid 0x20<link>
ether 48:b0:2d:7d:e5:20 txqueuelen 1000 (Ethernet)
RX packets 676 bytes 43234 (43.2 KB)
TX packets 295 bytes 38910 (38.9 KB)
nvidia@ubuntu:~$ sudo ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether d6:d6:4b:5d:01:27 brd ff:ff:ff:ff:ff:ff
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1466 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 48:b0:2d:7d:e5:20 brd ff:ff:ff:ff:ff:ff
4: l4tbr0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether b6:7e:7c:20:c8:b1 brd ff:ff:ff:ff:ff:ff
5: rndis0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN mode DEFAULT group default qlen 1000
6: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN mode DEFAULT group default qlen 1000
link/ether b6:7e:7c:20:c8:b3 brd ff:ff:ff:ff:ff:ff
7: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:70:79:82:4d brd ff:ff:ff:ff:ff:ff
nvidia@ubuntu:~$ ethtool -a eth0
Pause parameters for eth0:
Autonegotiate: on
RX: on
TX: on
RX negotiated: on
TX negotiated: on
Anyone experience this same issue or can think of any solution? Much appreciated!
