enlaihe
November 10, 2022, 10:08am
1
Hi nvidia team:
Following Bringing up an Ethernet Interface over PCIe and using tvnet in order to check bulk transfer between Orin EP and Orin RP,
RC command line exec lspci:
now the RC and EP both have eth1.
then set
On the endpoint device: ifconfig eth1 up
On the root port system: ifconfig eth1 up
On the endpoint device: ifconfig eth1 192.168.2.1
On the root port system: ifconfig eth1 192.168.2.2
when set EP ifconfig eth1 up
met some err.
and EP ping RC fail
here is the log.
rc-log.txt (63.3 KB)
ep-log.txt (57.8 KB)
please disable network manager on both side to prevent it interference.
enlaihe
November 11, 2022, 3:04am
4
WayneWWW:
network manager
Hi WayneWWW:
I have disable network manager on both side.
use service network-manager stop
still ping fail.
enlaihe
November 11, 2022, 3:40am
5
lspci -vvv:
0005:01:00.0 Network controller: NVIDIA Corporation Device 2296
Subsystem: NVIDIA Corporation Device 0000
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 55
Region 0: Memory at 2b28000000 (32-bit, non-prefetchable) [size=4M]
Region 2: Memory at 2740000000 (64-bit, prefetchable) [size=128K]
Region 4: Memory at 2b28400000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/16 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0 , Speed 16GT/s, Width x8, ASPM not supported
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (downgraded), Width x8 (ok) TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP-, LTR+
10BitTagComp+, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-, TPHComp-, ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
Vector table: BAR=2 offset=00000000
PBA: BAR=2 offset=00010000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap+ MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [148 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
LaneErrStat: 0
Capabilities: [168 v1] Physical Layer 16.0 GT/s <?>
Capabilities: [190 v1] Lane Margining at the Receiver <?>
Capabilities: [1b8 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [1c0 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us
L1SubCtl2: T_PwrOn=10us
Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308 v1] Data Link Feature <?>
Capabilities: [314 v1] Precision Time Measurement
PTMCap: Requester:+ Responder:- Root:-
PTMClockGranularity: Unimplemented
PTMControl: Enabled:- RootSelected:-
PTMEffectiveGranularity: Unknown
Capabilities: [320 v1] Vendor Specific Information: ID=0003 Rev=1 Len=054 <?>
Capabilities: [388 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
Kernel driver in use: tvnet
kayccc
November 23, 2022, 3:25am
6
Sorry for the late response, is this still an issue to support? Thanks
enlaihe
November 23, 2022, 3:40am
7
hi kayccc:
yes.I have change another orin.still ping error.
do I need modify some code to test?
or just follow Bringing up an Ethernet Interface over PCIe steps?
Please try to disable network manager.
$ sudo systemctl stop NetworkManager.service
$ sudo systemctl disable NetworkManager.service
And use below method to set static IP
1. sudo apt install netplan.io
2. Static IP Address Assignment
To configure your system to use static address assignment, create a netplan configuration in the file /etc/netplan/99_config.yaml. The example below assumes you are configuring your first Ethernet interface identified as eth0. Change the addresses, gateway4, and nameservers values to meet the requirements of your network.
network:
version: 2
renderer: networkd
ethernets:
eth0:
addresses:
- 10.10.10.2/24
gateway4: 10.10.10.1
Please refer to https://ubuntu.com/server/docs/network-configuration for details
hello,
Can I see how your ’99_config.yaml‘ is written and what the revised steps are, any steps that need to be omitted
system
Closed
December 23, 2022, 6:42am
11
