PCIe Maximum Payload Size only 128bytes
We have a custom board with a Xavier NX + PCIe Switch + FPGA. The Jetson is the PCIe root. All endpoints are capable of >= 256 bytes and this can be confirmed through lspci as well as the switch configuration software.
I mostly do FPGA work, so I don’t work with embedded Linux much, but there must be some way of getting the Jetson to NOT limit all of the endpoints to 128byte TLPs.
I’ve tried a few kernel boot parameters such as pci=pcie_bus_safe, pci=pcie_bus_perf, etc. (set in /boot/extlinux/extlinux.conf), but I have yet to find anything that helps.
Any help would be greatly appreciated!
Thanks,
Chip
You can download BSP source.
Decompress public_sources.tbz2 and then kernel_src.tbz2
The PCI source code path as it
=> /Linux_for_Tegra/source/public/kernel/nvidia/drivers/pci/dwc/pcie-tegra.c
You can check MPS as follows :
Kernel Build Guide
Hi Sumin,
I appreciate the help. It is useful to see where this is being set in the kernel code as we will eventually like to make this change there.
In the short term I have discovered it is possible to change this using setpci commands.
Thank you!
Chip
Thank you.
