Device Tree excerpt
pcie-controller@10003000 {
reg = <0x0 0x10003000 0x0 0x800 0x0 0x10003800 0x0 0x800 0x0 0x40000000 0x0 0x10000000>;
interrupts = <0x0 0x48 0x4 0x0 0x49 0x4>;
reg-names = "pads", "afi", "cs";
compatible = "nvidia,tegra186-pcie";
clock-names = "afi", "pcie", "clk_m";
reset-names = "afi", "pcie", "pciex";
bus-range = <0x0 0xff>;
interrupt-names = "intr", "msi";
device_type = "pci";
clocks = <0xd 0x4 0xd 0x3 0xd 0x261>;
#interrupt-cells = <0x1>;
power-domains = <0xad>;
ranges = <0x82000000 0x0 0x10000000 0x0 0x10000000 0x0 0x1000 0x82000000 0x0 0x10001000 0x0 0x10001000 0x0 0x1000 0x82000000 0x0 0x10004000 0x0 0x10004000 0x0 0x1000 0x81000000 0x0 0x0 0x0 0x50000000 0x0 0x10000 0x82000000 0x0 0x50100000 0x0 0x50100000 0x0 0x7f00000 0xc2000000 0x0 0x58000000 0x0 0x58000000 0x0 0x28000000>;
resets = <0xd 0x1 0xd 0x1d 0xd 0x1e>;
status = "okay";
#address-cells = <0x3>;
interrupt-map = <0x0 0x0 0x0 0x0 0x1 0x0 0x48 0x4>;
interrupt-map-mask = <0x0 0x0 0x0 0x0>;
phandle = <0x6a>;
#stream-id-cells = <0x1>;
vddio-pexctl-aud-supply = <0xe>;
#size-cells = <0x2>;
linux,phandle = <0x6a>;
prod-settings {
#prod-cells = <0x3>;
prod_c_pad {
prod = <0xc8 0xffffffff 0x80b880b8 0xcc 0xffffffff 0x480b8>;
pci@1,0 {
reg = <0x800 0x0 0x0 0x0 0x0>;
assigned-addresses = <0x82000800 0x0 0x10000000 0x0 0x1000>;
nvidia,disable-clock-request;
ranges;
status = "okay";
nvidia,afi-ctl-offset = <0x110>;
nvidia,num-lanes = <0x2>;
pci@2,0 {
reg = <0x1000 0x0 0x0 0x0 0x0>;
assigned-addresses = <0x82001000 0x0 0x10001000 0x0 0x1000>;
ranges;
status = "okay";
nvidia,afi-ctl-offset = <0x118>;
nvidia,num-lanes = <0x1>;
pci@3,0 {
reg = <0x1800 0x0 0x0 0x0 0x0>;
assigned-addresses = <0x82001800 0x0 0x10004000 0x0 0x1000>;
ranges;
status = "okay";
nvidia,afi-ctl-offset = <0x19c>;
We have our device connected to PEX2 as shown, I’m confused between port 2 and 3. So I’ve enabled both. A board by connect tech seems to detect the PCIe device, so I don’t think its a driver issue.
Let me know if I can provide more details, Thanks!
