PeopleNet model(.etlt) fails to work with JetPack4.6
• Hardware (T4/V100/Xavier/Nano/etc) Jetson Nano
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I have JetPack4.6 on a Jetson Nano and want to change the model from resnet10.caffemodel to PeopleNet model pruned_quantized_v2.3.2 based on
[deepstream_test_3.py](https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/v1.1.1/apps/deepstream -test3)
I did the following steps, but could not find the object.
Please advise.
1.convert resnet34_peoplenet_pruned_int8.etlt in pruned_quantized_v2.3.2 to save.engine
1.1 Download TAO toolkit
wget -O jp46-20210820t231431z-001.zip https://developer.nvidia.com/jp46-20210820t231431z-001zip
mkdir jp46- 20210820t231431z-001
unzip -d jp46-20210820t231431z-001 jp46-20210820t231431z-001.zip
1.2- Download the model
1.3 Generate engine file
desktop:~$ . /jp46-20210820t231431z-001/tao-converter-jp46-trt8.0.1.6/tao-converter -k tlt_encode -d 3,544,960 /root/models/peoplenet/peoplenet_ pruned_quantized_v2.3.2/resnet34_peoplenet_pruned_int8.etlt
desktop:~$
[INFO] [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 221, GPU 2805 (MiB)
[INFO] [MemUsageSnapshot] Builder begin: CPU 239 MiB, GPU 2836 MiB
[INFO] ---------- Layers Running on DLA ----------
[INFO] ---------- Layers Running on GPU ----------
[INFO] [GpuLayer] conv1/convolution + activation_1/Relu6
[INFO] [GpuLayer] block_1a_conv_1/convolution + block_1a_relu_1/Relu6
[INFO] [GpuLayer] block_1a_conv_shortcut/convolution
[INFO] [GpuLayer] block_1a_conv_2/convolution + add_1/add + block_1a_relu/Relu6
[INFO] [GpuLayer] block_1b_conv_1/convolution + block_1b_relu_1/Relu6
[INFO] [GpuLayer] block_1b_conv_shortcut/convolution
[INFO] [GpuLayer] block_1b_conv_2/convolution + add_2/add + block_1b_relu/Relu6
[INFO] [GpuLayer] block_1c_conv_1/convolution + block_1c_relu_1/Relu6
[INFO] [GpuLayer] block_1c_conv_shortcut/convolution
[INFO] [GpuLayer] block_1c_conv_2/convolution + add_3/add + block_1c_relu/Relu6
[INFO] [GpuLayer] block_2a_conv_1/convolution + block_2a_relu_1/Relu6
[INFO] [GpuLayer] block_2a_conv_shortcut/convolution
[INFO] [GpuLayer] block_2a_conv_2/convolution + add_4/add + block_2a_relu/Relu6
[INFO] [GpuLayer] block_2b_conv_1/convolution + block_2b_relu_1/Relu6
[INFO] [GpuLayer] block_2b_conv_shortcut/convolution
[INFO] [GpuLayer] block_2b_conv_2/convolution + add_5/add + block_2b_relu/Relu6
[INFO] [GpuLayer] block_2c_conv_1/convolution + block_2c_relu_1/Relu6
[INFO] [GpuLayer] block_2c_conv_shortcut/convolution
[INFO] [GpuLayer] block_2c_conv_2/convolution + add_6/add + block_2c_relu/Relu6
[INFO] [GpuLayer] block_2d_conv_1/convolution + block_2d_relu_1/Relu6
[INFO] [GpuLayer] block_2d_conv_shortcut/convolution
[INFO] [GpuLayer] block_2d_conv_2/convolution + add_7/add + block_2d_relu/Relu6
[INFO] [GpuLayer] block_3a_conv_1/convolution + block_3a_relu_1/Relu6
[INFO] [GpuLayer] block_3a_conv_shortcut/convolution
[INFO] [GpuLayer] block_3a_conv_2/convolution + add_8/add + block_3a_relu/Relu6
[INFO] [GpuLayer] block_3b_conv_1/convolution + block_3b_relu_1/Relu6
[INFO] [GpuLayer] block_3b_conv_shortcut/convolution
[INFO] [GpuLayer] block_3b_conv_2/convolution + add_9/add + block_3b_relu/Relu6
[INFO] [GpuLayer] block_3c_conv_1/convolution + block_3c_relu_1/Relu6
[INFO] [GpuLayer] block_3c_conv_shortcut/convolution
[INFO] [GpuLayer] block_3c_conv_2/convolution + add_10/add + block_3c_relu/Relu6
[INFO] [GpuLayer] block_3d_conv_1/convolution + block_3d_relu_1/Relu6
[INFO] [GpuLayer] block_3d_conv_shortcut/convolution
[INFO] [GpuLayer] block_3d_conv_2/convolution + add_11/add + block_3d_relu/Relu6
[INFO] [GpuLayer] block_3e_conv_1/convolution + block_3e_relu_1/Relu6
[INFO] [GpuLayer] block_3e_conv_shortcut/convolution
[INFO] [GpuLayer] block_3e_conv_2/convolution + add_12/add + block_3e_relu/Relu6
[INFO] [GpuLayer] block_3f_conv_1/convolution + block_3f_relu_1/Relu6
[INFO] [GpuLayer] block_3f_conv_shortcut/convolution
[INFO] [GpuLayer] block_3f_conv_2/convolution + add_13/add + block_3f_relu/Relu6
[INFO] [GpuLayer] block_4a_conv_1/convolution + block_4a_relu_1/Relu6
[INFO] [GpuLayer] block_4a_conv_shortcut/convolution
[INFO] [GpuLayer] block_4a_conv_2/convolution + add_14/add + block_4a_relu/Relu6
[INFO] [GpuLayer] block_4b_conv_1/convolution + block_4b_relu_1/Relu6
[INFO] [GpuLayer] block_4b_conv_shortcut/convolution
[INFO] [GpuLayer] block_4b_conv_2/convolution + add_15/add + block_4b_relu/Relu6
[INFO] [GpuLayer] block_4c_conv_1/convolution + block_4c_relu_1/Relu6
[INFO] [GpuLayer] block_4c_conv_shortcut/convolution
[INFO] [GpuLayer] block_4c_conv_2/convolution + add_16/add + block_4c_relu/Relu6
[INFO] [GpuLayer] output_bbox/convolution
[INFO] [GpuLayer] output_cov/convolution
[INFO] [GpuLayer] PWN(output_cov/Sigmoid)
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +154, now: CPU 406, GPU 2990 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +241, GPU +241, now: CPU 647, GPU 3231 (MiB)
[WARNING] Detected invalid timing cache, setup a local cache instead
[INFO] Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
[INFO] Detected 1 inputs and 2 output network tensors.
[INFO] Total Host Persistent Memory: 78336
[INFO] Total Device Persistent Memory: 26554368
[INFO] Total Scratch Memory: 0
[INFO] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 9 MiB, GPU 1239 MiB
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +4, now: CPU 893, GPU 2886 (MiB)
[INFO] [MemUsageChange] Init cuDNN: CPU +0, GPU +2, now: CPU 893, GPU 2888 (MiB)
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 893, GPU 2888 (MiB)
[INFO] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 892, GPU 2888 (MiB)
[INFO] [MemUsageSnapshot] Builder end: CPU 892 MiB, GPU 2888 MiB
  1. save “save.engine”, “labels.txt” in “pruned_quantized_v2.3.2” and “resnet34_peoplenet_pruned_int8.txt” in “pruned_quantized_v2.3.2” to /root/models Save it in /root/models 2.
  2. change the contents of dstest3_pgie_config.txt to the following:
[property]
gpu-id=0
net-scale-factor=1.0
model-engine-file=/root/models/peoplenet_pruned_quantized_v2.3.2/resnet34_peoplenet_pruned_int8.engine
labelfile-path=/root/models/peoplenet_pruned_quantized_v2.3.2/labels.txt
int8-calib-file=/root/models/peoplenet_pruned_quantized_v2.3.2/resnet34_peoplenet_int8.txt
batch-size=1
network-mode=1
num-detected-classes=3
interval=0
gie-unique-id=1
output-blob-names=output_bbox/Bias;output_cov/Sigmoid
cluster-mode=1
model-color-format=0
[class-attrs-all]
pre-cluster-threshold=0.5
topk=20
nms-iou-threshold=0.5
  1. Run deepstream_test_3.py to show a person on the connected camera, but no object is detected
  • The print on line 101 detects objects, but does not print “Objects=1”.
  • I have not modified deepstream_test_3.py for peoplenet, but expect “Objects=” to be “1”
print(“Frame Number=”, frame_number, “Number of Objects=”,num_ rects, “Vehicle_count=”,obj_counter[PGIE_CLASS_ID_VEHICLE], “Person_count=”,obj_counter[PGIE_CLASS_ID_PERSON])
This is a very legacy version. For pyds-1.1.1 to support peoplenet, you need to port the model and code yourself. It cannot run pruned_quantized_v2.3.2 directly.
You can refer to the guidance in deepstream_reference_apps(tag: DS_6.0). This peoplenet model has been verified on jp-4.6.
Thanks for the advice
I was able to get a detection with the “pruned_quantized_v2.1” you gave me.
However, I would like to run other Peoplenetmodels to check the accuracy of detection, etc.
Is there any
model of PeopleNet Model that can be run in .etlt format?
If so, please let me know the nvinfer configuration file (config_infer_
) and an example of using tao-converter.
v2.1 is already a model in etlt format, and this repository above also contains configuration file
The question was not accurate and seems to have caused misunderstanding.
I will ask the question again.
I want to run the following Version .etlt files at
[PeopleNet | NVIDIA NGC] They are
deployable_quantized_v2.5
deployable_quantized_v2.5.2
deployable_quantized_v2.6
deployable_quantized_v2.6.1
pruned_quantized_v2.1.1
pruned_quantized_v2.3.2 ← I understand that creating .engine will not work due to legacy versions.
pruned_v1.0
pruned_v2.0
pruned_v2.1
pruned_v2.3
Please let me know the “nvinfer configuration file (config_infer_)” and “how to convert .etlt to .engine (example of using tao-converter)” needed to get it working.
Do you mean that the “nvinfer configuration file (config_infer_)” for all versions is “deepstream_app_tao_configs/config_infer_primary_peoplenet.txt”
We cannot guarantee that other versions will run correctly with Jetpack 4.6. In other words, the peoplenet version is related to the jetpack version. Because tensorrt is part of jetpack.
If you want better results, you can finetune pruned_quantized_v2.1.
For deepstream 6.0, nvinfer will automatically convert the model from etlt to engine.
For tao-converter, refer to this command line.
./tao-converter -k tlt_encode -t int8 -c resnet34_peoplenet_pruned_int8_gpu.txt  -b 1 -d 3,544,960 -e resnet34_peoplenet_int8.etlt_b1_gpu0_int8.engine resnet34_peoplenet_pruned_int8.etlt
Thanks ,
Do you have a list of the versions of the people model and the corresponding versions of jetapck?
The tags in the deepstream_reference_apps repository correspond to different versions of deepstream, and the download_models.sh files with different tags show compatible versions.
Understood. Thank you very much.
