**• Hardware Platform (Jetson / GPU)**RTX3080
• DeepStream Version 6.4
PERF values are printed as follows in deepstream-app.
**PERF: 8.94 (8.62) 13.53 (13.32)
**PERF: 7.47 (8.06) 12.42 (12.81)
**PERF: 7.52 (7.82) 12.49 (12.74)
**PERF: 7.49 (7.76) 12.51 (12.65)
p
** INFO: <bus_callback:293>: Pipeline paused
r
** INFO: <bus_callback:287>: Pipeline running
After pausing the app and resume the app, the PERF are not printed anymore?
yuweiw
April 24, 2024, 10:50am
3
Could you try to modify the source code like below,
deepstream_perf.c
static gboolean
perf_measurement_callback (gpointer data)
if (str->stop) {
g_mutex_unlock (&str->struct_lock);
- return FALSE;
+ return TRUE;
So return TRUE and remove FALSE?
yuweiw
April 24, 2024, 10:56am
5
return TRUE. If you are in a hurry, this is a relatively simple solution. After full verification, we will submit a more perfect solution for this later.
system
Closed
May 8, 2024, 10:56am
6
