Performance Problem between CentOS 7.3 and Windows 10 via iperf - fio - etc. >> 40GBE
I have a strange network performance problem between Linux and Windows. I hope that somebody can help me to find a solution.
Setup 1:
Two machines with the follwing hardware:
Core i7, 8 Cores in summary with hyper threading
16GB RAM
Mellanox Connect-X3 40GBE >> PCI-Gen2-Slot >> about 25 Gbit
CentOS 7.3 as operating system
the latest ofed driver and firmware
I configured the settings in sysctl.conf as described in the guide. Furthermore I deactivated all offload-features, rss, interrupt moderation, etc.
In this setup and configuration I get around 21 Gbit/s between these two machines via iperf3 with 4 parallel streams in summary. That seems to be ok.
Setup 2:
Third machine hardware:
Xeon E5-2660 2,60 x 2
40 Cores in summary with hyper threading
64GB RAM
Mellanox Connect-X3 40GBE >> PCI-Gen3-Slot
Windows 10 Enterprise 64-bit with all updates installed
VPI-WinOF 5.35 driver
I also deactivated all features as I described before in Linux. I tried to disable autotuning for windows and configure congestionprovider etc. but I got a better performance when autotuning is set to normal.
Now I tested via iperf3 between Windows 10 and CentOS 7.3 Linux and I got only around 9,xx Gbit/s and not more!
Could somebody explain me what is going wrong here? I got the same results without a switch. I also tested the speed with same hardware and Windows 7 64-bit. The results with autotuning were around 2-3 Gbit/s better than with Windows 10.
Many thanks in advance!
Matthias
• Align all the fabric to a single max value of MTU
Please try: a fixed gap of 14 between Linux hosts and windows hosts (either decrease Linux by 14 or increase*** windows by 14
for example: Linux == 2030, Windows == 2044.
Let me know your results.
I added the following parameter to sysctl.conf:
net.ipv4.tcp_mtu_probing = 1
After a few seconds I got the same results about only 9 Gbit/s
sysctl.conf before adding the parameter:
net.ipv4.tcp_timestamps = 1
net.ipv4.tcp_sack = 1
net.ipv4.tcp_low_latency = 0
net.core.netdev_max_backlog = 250000
net.ipv4.tcp_rmem = 4096 87380 134217728
net.ipv4.tcp_wmem = 4096 65536 134217728
net.ipv4.tcp_congestion_control=htcp
net.core.default_qdisc=fq
net.ipv4.tcp_adv_win_scale = 2
net.ipv4.tcp_mem = 16777216 16777216 16777216
net.ipv4.tcp_reordering = 3
net.ipv4.tcp_limit_output_bytes = 131072
net.core.netdev_budget = 300
net.core.somaxconn = 2048
net.core.optmem_max = 268435456
net.core.rmem_default = 268435456
net.core.wmem_default = 268435456
net.core.rmem_max = 268435456
net.core.wmem_max = 268435456
In my standard configuration the MTU values are set to 1500 and 1514 and got the the results as I described before. If I change the values to 9000 or rather 9014 or your example values the performance breaks down to nothing.
[ 4] 7.00-7.36 sec 0.00 Bytes 0.00 bits/sec0 3.87 KBytes[ 6] 7.00-7.36 sec 0.00 Bytes 0.00 bits/sec0 3.87 KBytes[ 8] 7.00-7.36 sec 0.00 Bytes 0.00 bits/sec0 3.87 KBytes[ 10] 7.00-7.36 sec 0.00 Bytes 0.00 bits/sec0 3.87 KBytes[SUM] 7.00-7.36 sec 0.00 Bytes 0.00 bits/sec0
[ ID] Interval Transfer Bandwidth Retr[ 4] 0.00-7.36 sec 3.75 MBytes 4.28 Mbits/sec5 sender[ 4] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec receiver[ 6] 0.00-7.36 sec 3.75 MBytes 4.28 Mbits/sec5 sender[ 6] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec receiver[ 8] 0.00-7.36 sec 3.75 MBytes 4.28 Mbits/sec5 sender[ 8] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec receiver[ 10] 0.00-7.36 sec 3.75 MBytes 4.28 Mbits/sec5 sender[ 10] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec receiver[SUM] 0.00-7.36 sec 15.0 MBytes 17.1 Mbits/sec 20 sender[SUM] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec receiver
iperf3: interrupt - the client has terminated
Any idea for this results?
Nobody an idea?
The Windows Installation is not activated. Perhaps that could be a reason… but I do not think so!
