pgfotran : how to traceback
I want to know the location of a floating point operation error in pgfortran.
I would like to display the line number with traceback, if possible, without using the debugger.
In the next command option, the line number that stopped is not displayed.
pgfortran -Ktrap = fp test.f 90
I tried PGI_TERM environment variable, but this environment variable is not set properly.
set PGI_TERM = ‘1’
or
set PGI_TERM = ‘y’
Pgfortran say that PGI_TERM will be ineffective. I do not know the meaning and usage of PGI_TERM.
What should I do?
Hi sigebo,
Try setting PGI_TERM to “trace” to get a traceback.
Full details can be found here: User's Guide :: PGI version 18.5 Documentation for x86 and NVIDIA Processors
Hope this helps,
Mat
Thanks teach me the information of enviloment variables.
After setting PGI_TERM=trace , how to know the line number at the error.
I tried following.
set PGI_TERM=trace
pgfortran test.f90
warnig ieee-flotingpoint divide by zero is signaling
This result do not include any information of the error line no.
You may need to compile with “-g” to get the symbols.
Though since this is a floating point exception, compile with “-Ktrap=fp” and the compiler will halt and hopefully give you the line number.
-Mat
I used the -g -Ktrap options I taught, but I did not get an error line number.
I tried following
SET PGI_TERM=trap
PGFORTRAN -g -Ktrap=fp T.f90
result
Error: floating point exception
Warning: trace back not available, cannot read header
I cann’t any line number at error.
I think that something is missing.
Can you run the program in a debugger?
I misstaked typing.
Following is correct.
SET PGI_TERM=trace
T
result
I misstaked typing.
SET PGI_TERM=trace
T
result
I don’t want to use pgdbg such as GUI.
I want to debug on commandline and to know source line number at error.
Can I get this feacher on pgfortran ?
You can you pgdbg from the command line by adding the “-text” option. i.e. “pgdbg -text ”
-Mat
