I am installing HDF5 1.8.17 from source using PGI 19.10.
The package has installed with all prior versions of PGI.
With 19.10, I have successfully installed it on two systems but on my laptop (with the same OS and setup as the other systems) the compilation is failing with things like:
PGC-S-0039-Use of undeclared variable stdout (istore.c: 574)
PGC-S-0040-Illegal use of symbol, int (istore.c: 600)
Since it worked on another system, is there just something missing? On the other systems I have previous PGI installations still in the pgi directory whereas the laptop only has 19.10.
Any ideas?
- Ron
