Hello ,
I’m having a hard time compiling HDF5 library (I/O library) on a mac os x computer.
Here is the error the beginning of the error message:
pgcc -I. -I…/…/src -I…/…/src -c H5f90kit.c -o H5f90kit.o
PGC-S-0040-Illegal use of symbol, _fcd (./H5f90proto.h: 19)
PGC-W-0156-Type not specified, ‘int’ assumed (./H5f90proto.h: 19)
PGC-S-0040-Illegal use of symbol, int_f (./H5f90proto.h: 62)
PGC-W-0156-Type not specified, ‘int’ assumed (./H5f90proto.h: 62)
When I look at the H5f90proto.h file
lines 19 and 62 look like this
19: H5_FCDLL char * HD5f2cstring (_fcd fdesc, size_t len);
62: H5_FCDLL int_f nh5fcreate_c (_fcd name, int_f *namelen, int_f *access_flags, hid_t_f *crt_prp, hid_t_f *acc_prp, hid_t_f *file_id);
Any ideas ?
Hi neldorth,
It looks like the file fortran/src/H5f90i.h needs to be updated to include configuration options for OSX and PGI. Adding the following seemed to do it:
/* MAC APPLE definitions with PGI compiler*/
#if defined(__osx86) && defined(__PGI)
typedef char *_fcd;
typedef long long haddr_t_f;
typedef long long hsize_t_f;
typedef long long hssize_t_f;
typedef int size_t_f;
typedef int int_f;
typedef int hid_t_f;
typedef float real_f;
#define FNAME_POST_UNDERSCORE
#define _fcdtocp(desc) (desc)
#endif /*OSX PGI*/
I encountered another error with fortran/src/H5fortran_types.f90 where the configure script is suppose to add some datatype information but instead left it blank. To work around this problem I updated the file to use the following which I generated on Linux.
INTEGER, PARAMETER :: R_LARGE = 18
INTEGER, PARAMETER :: R_INTEGER = 9
INTEGER, PARAMETER :: HADDR_T = SELECTED_INT_KIND(R_LARGE)
INTEGER, PARAMETER :: HSIZE_T = SELECTED_INT_KIND(R_LARGE)
INTEGER, PARAMETER :: HSSIZE_T = SELECTED_INT_KIND(R_LARGE)
INTEGER, PARAMETER :: HID_T = SELECTED_INT_KIND(R_INTEGER)
INTEGER, PARAMETER :: SIZE_T = SELECTED_INT_KIND(R_INTEGER)
! Some HDF5 FORTARN90 default values ( here for now 8/5/99 EIP )
INTEGER(SIZE_T), PARAMETER :: OBJECT_NAMELEN_DEFAULT_F = -1
With these changes, it built for me on 64-bit OSX and all the test codes passed. However, I did not test it with real application. Please let us know how it goes.
Thanks i’ll try that right away. Just wanted to point out that the 1.8 beta for HDF seems to have corrected all this issues. Configure , compilation go smoothly. I’m currently testing on a real App.
I’ll try you modifications too since i prefer to keep 1.6.5 for now.
