I am trying accelerate an application which passes part of a Fortran array to a subroutine. The example below best explains what I mean. The first half of the array is multiplied by 2 and the second half by 3.
I would like the subroutine to use the data in the GPU memory to avoid data copying overheads. I try to do this using the reflected clause.
The code is correct Fortran (and representative of the original application), but I get compiler error messages of the form:
PGF90-S-0486-The dummy argument v is REFLECTED; an array element cannot be passed to a REFLECTED argument (t.F90: 35)
Am I using the clause wrongly?
Will I be able to do this using the “device resident” clause, when it is supported?
Cheers,
Alistair.
The code is:
MODULE mm
CONTAINS
SUBROUTINE double_part(v,n,f)
IMPLICIT NONE
INTEGER, INTENT(in) :: n,f
INTEGER, INTENT(inout) :: v(n)
!$acc reflected(v)
INTEGER :: i
!$acc region
DO i = 1,n
v(i) = f*v(i)
ENDDO
!$acc end region
END SUBROUTINE double_part
END MODULE mm
PROGRAM test
USE mm
IMPLICIT NONE
INTEGER, PARAMETER :: N = 5
INTEGER :: u(2*N)
INTEGER :: i,tot,expected
!$acc data region
!$acc region
DO i = 1,2*N
u(i) = i
ENDDO
!$acc end region
CALL double_part(u(1),N,2)
CALL double_part(u(N+1),N,3)
!$acc region
tot = SUM(u(:))
!$acc end region
!$acc end data region
expected = 2*(N*(N+1)/2) + 3*(2*N*(2*N+1)/2-n*(N+1)/2)
PRINT *,tot," validated? ",(tot == expected)
END PROGRAM test
