Hi, do you mind letting us know what method of detection that was used for the ResNet-10 model that is used as the primary inference engine?
Also, when the pgie configuration is set to “isInference=1”, where is the inference result carried?
There is no “isInference” config.
Carried in gstreamer metadata.
I’m sorry, I mean the “is-classifier” property.
Do you mean the
GstMeta *gst_meta
data?
You can set is-classifier if your pgie is classifier for full frame.
Yes. You can run our test samples.
