When there’s an error, there should be a message something like: “An error has occurred. See the log file nvvp-workspace/.metadata/.log”. Where “nvvp-workspace” is located in your $HOME directory. If this error log exists, can you post or send it to PGI Customer Service (trs@pgroup.com)?
There was no error message like “An error has occured…”
Only: “java: /build/buildd/gtk2-engines-oxygen-1.4.5/src/animations/oxygencomboboxdata.cpp:87: void Oxygen::ComboBoxData::setButton(GtkWidget*): Zusicherung »!_button._widget« nicht erfüllt.”
$ more /etc/issue
Ubuntu 14.04.4 LTS
$ which java
/usr/bin/java
$ java -version
java version "1.7.0_95"
OpenJDK Runtime Environment (IcedTea 2.6.4) (7u95-2.6.4-0ubuntu0.14.04.1)
OpenJDK 64-Bit Server VM (build 24.95-b01, mixed mode)
$ more ~/nvvp_workspace/.metadata/.log
!SESSION 2016-02-25 09:51:13.914 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_45
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments: -product com.nvidia.pgprof.application.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -data @user.home/nvvp_workspace -product com.nvidia.pgprof.application.product
!ENTRY org.eclipse.core.resources 2 10035 2016-02-25 09:51:15.522
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 4 4 2016-02-25 09:51:16.987
!MESSAGE Referenced part does not exist yet: org.eclipse.ui.editors.
!SESSION 2016-02-25 09:52:43.460 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2016-02-25 09:52:44.990
!ENTRY org.eclipse.ui 4 4 2016-02-25 09:52:46.440
