I would like to include PhysX in my project as a NuGet package. When creating the NuGet package I need to set the projects runtime settings from MT/MTd to MD/MDd int order for it to be compatible with my projects. This all seems to work and the NuGet package is created, however, I have some trouble with the initialization of the PxPhysics object.
pxPhysics = PxCreatePhysics(PX_PHYSICS_VERSION, *pxFoundation, toleranceScale, recordMemoryAllocations);
When calling this function a nullptr is returned. Has anyone run into an issue similar to this? Does it have to do with the creation of the NuGet package?
Figured I might just have made a mistake in my initialization code so here it is:
using namespace physx;
static PxFoundation* pxFoundation = nullptr;
static PxCooking* pxCooking = nullptr;
static PxPhysics* pxPhysics = nullptr;
void Initialize()
PxDefaultErrorCallback gDefaultErrorCallback;
PxDefaultAllocator gDefaultAllocatorCallback;
auto tolerance = (PxReal)100.0;
PxTolerancesScale toleranceScale;
toleranceScale.length = tolerance;
toleranceScale.mass = tolerance;
toleranceScale.speed = tolerance;
pxFoundation = PxCreateFoundation(PX_FOUNDATION_VERSION, gDefaultAllocatorCallback, gDefaultErrorCallback);
bool recordMemoryAllocations = true;
PxCookingParams cookingParams(toleranceScale);
cookingParams.suppressTriangleMeshRemapTable = false;
cookingParams.meshWeldTolerance = tolerance;
cookingParams.meshPreprocessParams = PxMeshPreprocessingFlag::eDISABLE_CLEAN_MESH;
pxCooking = PxCreateCooking(PX_PHYSICS_VERSION, *pxFoundation, cookingParams);
Side note: I also ran this same code by including PhysX as a library and then it worked fine.
