I was trying to follow this tutorial,
and have a strange pickle error, the file does not appear to be empty
trinhjames@trinhjames-desktop:~/jetson-inference/python/training/detection/ssd$ python3 train_ssd.py --dataset-type=voc --data=data/door --model-dir=model/new
/home/trinhjames/.local/lib/python3.7/site-packages/torchvision/io/image.py:13: UserWarning: Failed to load image Python extension:
warn(f"Failed to load image Python extension: {e}")
2023-07-13 13:56:47 - Namespace(balance_data=False, base_net=None, base_net_lr=0.001, batch_size=4, checkpoint_folder=‘model/new’, dataset_type=‘voc’, datasets=[‘data/door’], debug_steps=10, extra_layers_lr=None, freeze_base_net=False, freeze_net=False, gamma=0.1, log_level=‘info’, lr=0.01, mb2_width_mult=1.0, milestones=‘80,100’, momentum=0.9, net=‘mb1-ssd’, num_epochs=30, num_workers=2, pretrained_ssd=‘models/mobilenet-v1-ssd-mp-0_675.pth’, resolution=300, resume=None, scheduler=‘cosine’, t_max=100, use_cuda=True, validation_epochs=1, validation_mean_ap=False, weight_decay=0.0005)
2023-07-13 13:56:48 - model resolution 300x300
2023-07-13 13:56:48 - SSDSpec(feature_map_size=19, shrinkage=16, box_sizes=SSDBoxSizes(min=60, max=105), aspect_ratios=[2, 3])
2023-07-13 13:56:48 - SSDSpec(feature_map_size=10, shrinkage=32, box_sizes=SSDBoxSizes(min=105, max=150), aspect_ratios=[2, 3])
2023-07-13 13:56:48 - SSDSpec(feature_map_size=5, shrinkage=64, box_sizes=SSDBoxSizes(min=150, max=195), aspect_ratios=[2, 3])
2023-07-13 13:56:48 - SSDSpec(feature_map_size=3, shrinkage=100, box_sizes=SSDBoxSizes(min=195, max=240), aspect_ratios=[2, 3])
2023-07-13 13:56:48 - SSDSpec(feature_map_size=2, shrinkage=150, box_sizes=SSDBoxSizes(min=240, max=285), aspect_ratios=[2, 3])
2023-07-13 13:56:48 - SSDSpec(feature_map_size=1, shrinkage=300, box_sizes=SSDBoxSizes(min=285, max=330), aspect_ratios=[2, 3])
2023-07-13 13:56:48 - Prepare training datasets.
2023-07-13 13:56:48 - VOC Labels read from file: (‘BACKGROUND’, ‘First’, ‘Second’)
2023-07-13 13:56:48 - Stored labels into file model/new/labels.txt.
2023-07-13 13:56:48 - Train dataset size: 20
2023-07-13 13:56:48 - Prepare Validation datasets.
2023-07-13 13:56:48 - Validation dataset size: 5
2023-07-13 13:56:48 - Build network.
2023-07-13 13:56:48 - Init from pretrained SSD models/mobilenet-v1-ssd-mp-0_675.pth
File “train_ssd.py”, line 371, in
net.init_from_pretrained_ssd(args.pretrained_ssd)
File “/home/trinhjames/jetson-inference/python/training/detection/ssd/vision/ssd/ssd.py”, line 133, in init_from_pretrained_ssd
state_dict = torch.load(model, map_location=lambda storage, loc: storage)
File “/home/trinhjames/.local/lib/python3.7/site-packages/torch/serialization.py”, line 795, in load
return _legacy_load(opened_file, map_location, pickle_module, **pickle_load_args)
File “/home/trinhjames/.local/lib/python3.7/site-packages/torch/serialization.py”, line 1002, in _legacy_load
magic_number = pickle_module.load(f, **pickle_load_args)
EOFError: Ran out of input
Any help is appreciated, thanks for the in depth tutorials.
