File “train_ssd.py”, line 309, in
net.init_from_pretrained_ssd(args.pretrained_ssd)
File “/jetson-inference/python/training/detection/ssd/vision/ssd/ssd.py”, line 119, in init_from_pretrained_ssd
state_dict = torch.load(model, map_location=lambda storage, loc: storage)
File “/usr/local/lib/python3.6/dist-packages/torch/serialization.py”, line 608, in load
return _legacy_load(opened_file, map_location, pickle_module, **pickle_load_args)
File “/usr/local/lib/python3.6/dist-packages/torch/serialization.py”, line 777, in _legacy_load
magic_number = pickle_module.load(f, **pickle_load_args)
EOFError: Ran out of input
It looks like there are some issues when opening the pickle file.
Do you follow the instructions below to run the retraining?
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/deep-vision-header.jpg" width="100%">
<p align="right"><sup><a href="pytorch-collect.md">Back</a> | <a href="pytorch-collect-detection.md">Next</a> | </sup><a href="../README.md#hello-ai-world"><sup>Contents</sup></a>
<br/>
<sup>Transfer Learning - Object Detection</sup></s></p>
# Re-training SSD-Mobilenet
Next, we'll train our own SSD-Mobilenet object detection model using PyTorch and the [Open Images](https://storage.googleapis.com/openimages/web/visualizer/index.html?set=train&type=detection&c=%2Fm%2F06l9r) dataset. SSD-Mobilenet is a popular network architecture for realtime object detection on mobile and embedded devices that combines the [SSD-300](https://arxiv.org/abs/1512.02325) Single-Shot MultiBox Detector with a [Mobilenet](https://arxiv.org/abs/1704.04861) backbone.
<a href="https://arxiv.org/abs/1512.02325"><img src="https://github.com/dusty-nv/jetson-inference/raw/dev/docs/images/pytorch-ssd-mobilenet.jpg"></a>
In the example below, we'll train a custom detection model that locates 8 different varieties of fruit, although you are welcome to pick from any of the [600 classes](https://github.com/dusty-nv/pytorch-ssd/blob/master/open_images_classes.txt) in the Open Images dataset to train your model on. You can visually browse the dataset [here](https://storage.googleapis.com/openimages/web/visualizer/index.html?set=train&type=detection).
<img src="https://github.com/dusty-nv/jetson-inference/raw/dev/docs/images/pytorch-fruit.jpg">
To get started, first make sure that you have [JetPack 4.4](https://developer.nvidia.com/embedded/jetpack) or newer and [PyTorch installed](pytorch-transfer-learning.md#installing-pytorch) for **Python 3.6** on your Jetson. JetPack 4.4 includes TensorRT 7.1, which is the minimum TensorRT version that supports loading SSD-Mobilenet via ONNX. And the PyTorch training scripts used for training SSD-Mobilenet are for Python3, so PyTorch should be installed for Python 3.6.
## Setup
> **note:** first make sure that you have [JetPack 4.4](https://developer.nvidia.com/embedded/jetpack) or newer on your Jetson and [PyTorch installed](pytorch-transfer-learning.md#installing-pytorch) for **Python 3.6**
This file has been truncated. show original
Could you share more details about your steps with us?
It would seem that the base model is corrupted - can you try downloading it again?
cd jetson-inference/python/training/detection/ssd
wget https://nvidia.box.com/shared/static/djf5w54rjvpqocsiztzaandq1m3avr7c.pth -O models/mobilenet-v1-ssd-mp-0_675.pth
Hi Dusty,
Thank you for your help. Yes, indeed the model wasn’t downloaded properly. I found another source to download since the box link isn’t working in China.
Simon
发自我的iPad
