• Hardware Platform GPU • DeepStream Version 6.4 • NVIDIA GPU Driver Version - NVIDIA GeForce GTX 1650 / Driver Version: 525.147.05 / CUDA Version: 12.0 • Issue Type( questions, new requirements, bugs)
It is not happening everytime and no error shows up but my pipeleine freezes sometimes after a couple of frames.
In addition, the inference only starts to work after 3 or 4 frames.
Please find attached the PDF of my architecture. graph.pdf (31.3 KB)
I would assume, that there is queue somewhere missing or I did the design of the pipeline not correct.
On purpose for testing purposes, I am using only one hw_encoder, as later there will 13 streams running over this pipeline.
Would it be better if I use mux first for source bins and then tee to split between the two different paths (1. save original video as hls and 2. create ai video as hls)? Wouldn’t be a slight overhead for to copy first to GPU and then back to CPU again?
Thanks for reply, I will try the pipeline first without software encoder.
However, on more question, as you can see from my architecture I have 2 input streams and want also to produce output hls streams.
In my pipeline I have workflow as follows:
2 streams -> mux -> pgie -> tracker -> nvdconvert -> osd -> demux
for each pad in demux -> nvv4l2h264enc -> h264parse -> hlssink2
However, only one stream gets annotated and the other one is not. From what I understood, osd cannot can process batch but demux cannot propoerly unbatch it.
So in order to fix, should the process be:
2 streams -> mux -> pgie -> tracker -> demux
for each pad in demux -> nvdconvert -> osd -> nvv4l2h264enc -> h264parse -> hlssink2
I could not find any proper documentation for nvv4l2h264enc. is this the right module use?
In the link you posted, I cannot find anything with regards to “nvv4l2h264enc”… this is about “nvvideo4linux2”… Should this module be used instead in the pipeline?
Nvvideo4linux2 is a general term for codec plug-ins. It contains decoders and encoders. Nvv4l2h264enc is one of the encoder plugin.
gst-inspect-1.0 nvvideo4linux2
Plugin Details:
Name nvvideo4linux2
Description Nvidia elements for Video 4 Linux
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so
Version 1.14.0
License LGPL
Source module nvvideo4linux2
Binary package nvvideo4linux2
Origin URL http://nvidia.com/
nvv4l2av1enc: V4L2 AV1 Encoder
nvv4l2decoder: NVIDIA v4l2 video decoder
nvv4l2h264enc: V4L2 H.264 Encoder
nvv4l2h265enc: V4L2 H.265 Encoder
