**• Hardware Platform (Jetson / GPU)**Jetson Orin NX 16GB
• DeepStream Version 6.2
**• JetPack Version (valid for Jetson only)**5.1.1
• TensorRT Version 8.5.2
• Issue Type( questions, new requirements, bugs) questions
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) command line
Hi, this pipeline command stops as soon as it executes.
I couldn’t find the reason.
I wrote it at the c++ source level, but this didn’t work.
Therefore, I tested with gst-launch-1.0. However, the issue that stops immediately after executing the command is the same.
The first command line I tried is as follows.
gst-launch-1.0 \
v4l2src device=/dev/video0 \
! "image/jpeg,width=1280,height=720,framerate=30/1" \
! jpegdec ! videoconvert ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,framerate=30/1" \
! nvstreammux0.sink_0 nvstreammux name=nvstreammux0 width=720 height=720 batch-size=1 ! queue \
! nvmultistreamtiler ! queue ! nvvideoconvert ! queue \
! nvdsosd ! queue ! tee name=video0 \
video0. ! nvegltransform ! nveglglessink sync=false \
video0. ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=I420" ! nvv4l2h264enc ! h264parse ! splitmuxsink max-size-time=30000000000 location=/home/nvidia/videos/test_%05d.mp4
And I tried simplifying this command line into a file stream. But the status quo is the same.
gst-launch-1.0 \
uridecodebin uri="file:///opt/nvidia/deepstream/deepstream-6.2/samples/streams/sample_720p.mp4" \
The symptoms I observed seem to stop when the line that forms splitmuxsink is added at the branch of the tee.
