Cannot start pipeline running python test app 1
• Hardware Platform (Jetson / GPU) NVIDIA Orin NX Developer Kit
• DeepStream Version 6.3.0
• JetPack Version (valid for Jetson only) R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
• TensorRT Version 8.5.2-1+cuda11.4
Note: I can currently on DeepStream_Python_Apps_Bindings_v1.1.8
I am trying to run Deepstream-test1 with python ./deepstream_test_1.py …/…/…/…/samples/streams/sample_720p.h264. I get the error:
Starting pipeline
Error: gst-core-error-quark: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure. (4): gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNv3dSink:nv3d-sink:
Failed to start
if I change the sink to nveglstreamsrc, the it get
Starting pipeline
Opening in BLOCKING MODE
0:00:00.205987578 63555     0x119dfac0 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1174> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:02.958693413 63555     0x119dfac0 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x544x960
1   OUTPUT kFLOAT conv2d_bbox     16x34x60
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x34x60
0:00:03.128983386 63555     0x119dfac0 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:03.252724591 63555     0x119dfac0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
NvEglStreamSrc: Can not start because egl_display and stream are not set
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
Error: gst-core-error-quark: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure. (4): gstbasesrc.c(3468): gst_base_src_start (): /GstPipeline:pipeline0/GstNvEglStreamSrc:nv3d-sink:
Failed to start
Can you check if the method in this topic works for your case? Faced an error running “deepstream_python_apps/apps/runtime_source_add_delete” - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
I’ve tried that solution, it doesn’t work. thanks
How do you run the program? Is it in ssh?
What is the result of the following command?
The value that you usually set DISPLAY to in ssh
cat /proc/$(pidof "gnome-terminal-server")/environ | tr '\0' '\n' | grep ^DISPLAY=
Yes it is in ssh. I run it as such sudo python3 ./deepstream_test_1.py ../../../../samples/streams/sample_720p.h264
When I run cat /proc/$(pidof "gnome-terminal-server")/environ | tr '\0' '\n' | grep ^DISPLAY= it says DISPLAY=:1
I’ve tried setting DISPLAY=:0 but it gives the same error.
When I run it on the Jetson, it does it no problem.
I think you should try setting export DISPLAY=:1.
DeepStream does not support x11-forwarding, so when you use ssh, you need to execute export DISPLAY=:x
I’m getting the same error for DISPLAY=:1.
Do not use sudo, otherwise environment variables will be lost.
If the /opt directory is not writable, use sudo chmod -R 777
thanks, the pipeline runs successfully but the actual display of the cars and people do not show.
This is normal since x11-forwarding is not supported.
The program will not be displayed on ssh, it can only be displayed on the host side
