Pipeline fails to create DeepStream test 4
Jetson
• DeepStream Version
Latest
question
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! nvstreammux0.sink_0 nvstreammux name=nvstreammux0 batch-size=1 width=1920 height=1080 ! nvinfer batch-size=1 config-file-path=/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test4/dstest4_pgie_config.txt ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
This pipeline reports back:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test4/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:01.798975578 14538   0x557ecf4640 WARN                 nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test4/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:01.799054694 14538   0x557ecf4640 WARN                 nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test4/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:01.799087039 14538   0x557ecf4640 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:26.033950041 14538   0x557ecf4640 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1748> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:26.076470306 14538   0x557ecf4640 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:./dstest4_pgie_config.txt sucessfully
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:26.263715254 14538   0x557e642400 WARN                 nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop:<nvinfer0> error: Internal data stream error.
0:00:26.264013228 14538   0x557e642400 WARN                 nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop:<nvinfer0> error: streaming stopped, reason not-linked (-1)
ERROR: from element /GstPipeline:pipeline0/GstNvInfer:nvinfer0: Internal data stream error.
Additional debug info:
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1975): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:nvinfer0:
Execution ended after 0:00:00.186390246
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
And it fails to run.
The pipeline you posted can work well in my Jetson board.
I have the same problem, with DS 4.
Actually, the pipeline I posted did work, however, when I add the MQTT pipeline in, it does not work:
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! nvstreammux0.sink_0 nvstreammux name=nvstreammux0 batch-size=1 width=1920 height=1080 ! nvinfer batch-size=1 config-file-path=/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test4/dstest4_pgie_config.txt queue ! tee name=infres \
infres. ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink \
infres. ! nvmsgconv config=/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test4/dstest4_msgconv_config.txt payload-type=0 ! nvmsgbroker proto-lib=/opt/nvidia/deepstream/deepstream-5.0/sources/libs/aws_protocol_adaptor/device_client/libnvds_aws_proto.so config=/opt/nvidia/deepstream/deepstream-5.0/sources/libs/aws_protocol_adaptor/device_client/cfg_aws.txt topic=ryantest conn-str=aidnfuomgla6i-ats.iot.us-east-1.amazonaws.com:443
We are using AWS MQTT broker, if that’s not available to you, could you provide a sample Kafka or other MQTT broker command line?
Deepstream supports Azure MQTT Protocol with nvmsgbroker. The deepstream sample is in /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test4. Please read the README file under the folder.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvmsgbroker.html#
According to the docs, we can put own our library via the
‘proto-lib=’ parameter which is what we are doing. We have build our own library for AWS which works fine with testapp4, but not in this case. @Fiona.Chen are you saying Deepstream nvmsgbrooker pipeline plugin ONLY supports Azure and the proto-lib functionality is broken?
No. nvmsgbroker can support customized protocol adapter.Gst-nvmsgbroker — DeepStream 6.3 Release documentation
Since your new proto lib can work with deepstream-test4, there is no problem with the gst-launch-1.0 pipeline. The only difference between deepstream-test4 and the gst-launch pipeline is that deepstream-test4 use “osd_sink_pad_buffer_probe” probe function to generate NvDsEventMsgMetawhich is the message can be send to cloud but the gst-launch pipeline can not. The nvmsgconv must be used in a gstreamer application but not gst-launch pipeline.
