**• Hardware Platform (Jetson / GPU)**gpu
• DeepStream Version7.1 docker
use nvmultiurisrcbin, offen crash in end of stream
nvstreammux: Successfully handled EOS for source_id=0
Element Message from multi-uri_creator: stream-remove - stream-remove, source-id=(uint)0, sensor-id=(string)stream0, sensor-name=(string)front_door, uri=(string)file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4;
0:00:59.369365665 4395 0x7f234c000d80 ERROR v4l2allocator gstv4l2allocator.c:1398:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 0: Bad file descriptor
0:00:59.369402478 4395 0x7f234c000d80 ERROR v4l2bufferpool gstv4l2bufferpool.c:1498:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 0
0:00:59.382796974 4395 0x7f234c000d80 ERROR v4l2allocator gstv4l2allocator.c:1398:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Bad file descriptor
0:00:59.382874952 4395 0x7f234c000d80 ERROR v4l2bufferpool gstv4l2bufferpool.c:1498:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
Warning: gst-resource-error-quark: No Sources found at the input of muxer. Waiting for sources. (3): gstnvstreammux.cpp(2893): gst_nvstreammux_src_push_loop (): /GstPipeline:pipeline0/GstDsNvMultiUriBin:multi-uri/GstBin:multi-uri_creator/GstNvStreamMux:src_bin_muxer
0:00:59.383259923 4395 0x7f234c000d80 ERROR v4l2allocator gstv4l2allocator.c:1398:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 2: Bad file descriptor
0:00:59.383267778 4395 0x7f234c000d80 ERROR v4l2bufferpool gstv4l2bufferpool.c:1498:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 2
my some code is
nvvidconv_tiler = Gst.ElementFactory.make("nvvideoconvert", "nvvidconv_tiler")
if not nvvidconv_tiler:
logger.error(f"Unable to create nvvidconv_tiler\n")
filter_tiler = Gst.ElementFactory.make("capsfilter", "filter_tiler")
if not filter_tiler:
logger.error(f"Unable to create filter_tiler\n")
filter_tiler.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA"))
nvvidconv_encoder = Gst.ElementFactory.make("nvvideoconvert", "nvvidconv_encoder")
if not nvvidconv_encoder:
logger.error(f"Unable to create nvvidconv_encoder\n")
filter_encoder = Gst.ElementFactory.make("capsfilter", "filter_encoder")
if not filter_encoder:
logger.error(f"Unable to create filter_encoder\n")
filter_encoder.set_property("caps",Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
if not encoder:
logger.error(f"Unable to create encoder\n")
encoder.set_property('tuning-info-id', 2)
encoder.set_property('control-rate', 2)
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
if not rtppay:
logger.error(f"Unable to create rtppay\n")
logger.info("Adding elements to Pipeline \n")
pipeline.add(xxxxxxx)
logger.info("Linking elements in the Pipeline \n")
source.link(pgie)
pgie.link(queue_tee)
queue_tee.link(tee)
tee.link(queue_msgconv)
queue_msgconv.link(msgconv)
msgconv.link(queue_msgbroker)
queue_msgbroker.link(msgbroker)
if args.output=="rtsp":
tee.link(queue_tiler)
queue_tiler.link(nvvidconv_tiler)
nvvidconv_tiler.link(filter_tiler)
filter_tiler.link(nvtiler)
nvtiler.link(nvosd)
nvosd.link(nvvidconv_encoder)
nvvidconv_encoder.link(filter_encoder)
filter_encoder.link(encoder)
encoder.link(rtppay)
rtppay.link(sink)
