DeepStream segmentation fault causes the program to crash
• Hardware Platform (Jetson )
• DeepStream 6.2 Version
• JetPack Version (5.1.3)
• TensorRT Version (8.5.2.2)
• Issue Type( bugs)
• How to reproduce the issue ?
When running the following code for a long time, a segmentation fault occasionally occurs. Please help me check whether the issue is with my code or a bug in the DeepStream SDK.
#include "deepstream.h"
#include <sstream>
//#include <spdlog/spdlog.h>
#include <gstnvdsmeta.h>
#include <nvbufsurface.h>
#include <exception>
//#include "../util/singleton.h"
#include <opencv2/opencv.hpp>
#include <ros/console.h>
#include <ros/ros.h>
#include <filesystem>
#include <std_msgs/String.h>
#include <modules/util/psdk_util.h>
#include "wrapper/wrapper.h"
using namespace deepstream;
std::mutex g_mtxFocusdata;
std::vector<cv::Mat> g_VecFocusmat = std::vector<cv::Mat>();
// �����ŶȽ������еıȽϺ���
bool compareConfidence(const NvDsObjectMeta\* a, const NvDsObjectMeta\* b) {
    return a->confidence > b->confidence;
static GstPadProbeReturn osd_sink_pad_buffer_probe (GstPad \* pad, GstPadProbeInfo \* info, gpointer u_data)
  try
    if(PSDK_Wrapper::get_instance()->m_bTaskState)
      GstBuffer \*buf = (GstBuffer \*)info->data;
      if(!buf)
        USER_LOG_INFO("osd_sink_pad_buffer_probe-- buf is null");
        return GST_PAD_PROBE_OK;
      GstMapInfo in_map_info;
      NvBufSurface \*surface = NULL;
      NvDsObjectMeta \*obj_meta = NULL;
      NvDsMetaList \* l_frame = NULL;
      NvDsMetaList \* l_obj = NULL;
    if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ))
          g_print ("osd_sink_pad_buffer_probe-- gst_buffer_map() error!");
          USER_LOG_INFO("osd_sink_pad_buffer_probe-- gst_buffer_map() error");
          //gst_buffer_unmap(buf, &in_map_info);
      surface =  (NvBufSurface \*) in_map_info.data;
      if(!surface)
        USER_LOG_INFO("osd_sink_pad_buffer_probe-- surface is null");
      NvDsBatchMeta \*batch_meta = gst_buffer_get_nvds_batch_meta (buf);
      if(!batch_meta)
        USER_LOG_INFO("osd_sink_pad_buffer_probe-- batch_meta is null");
      for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
          NvDsFrameMeta \*frame_meta = (NvDsFrameMeta \*) (l_frame->data);
          if(!frame_meta)
            //spdlog::info("osd_sink_pad_buffer_probe-- frame_meta is null");
            break;
          if(frame_meta->num_obj_meta<=0){
             //ROS_INFO("No objects were detected.");
             //spdlog::info("osd_sink_pad_buffer_probe-- No objects were detected.");
             break;
          std::vector<NvDsObjectMeta\*> label_J_objects;
          std::vector<NvDsObjectMeta\*> other_objects;
          for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next)
              if(!l_obj->data){
                  USER_LOG_INFO("osd_sink_pad_buffer_probe-- l_obj data is null");
                  continue;
              obj_meta = (NvDsObjectMeta \*) (l_obj->data);
              if(!obj_meta)
                USER_LOG_INFO("osd_sink_pad_buffer_probe-- obj_meta is null");
                break;
              std::string label = obj_meta->obj_label;
              if (label == "JianGeBang" ) {
                 if(PSDK_Wrapper::get_instance()->isJGBFly){
                    label_J_objects.push_back(obj_meta);
              } else {
                 other_objects.push_back(obj_meta);
          //���������Ŀ��
          if(label_J_objects.size() > 0){
            //�������3������ȡ���Ŷ���ߵ�3��
             if(label_J_objects.size() > 3){
                std::sort(label_J_objects.begin(), label_J_objects.end(), compareConfidence);
                label_J_objects.resize(3);
             // ����ÿ�����󣬻�ȡ x, y, w, h ��ƴ�ӳ��ַ���
            std::string result;
            for (const auto& obj : label_J_objects) {
                  std::ostringstream oss;
                  oss << std::fixed << std::setprecision(2) << obj->rect_params.left << ","
                      << std::fixed << std::setprecision(2) << obj->rect_params.top << ","
                      << std::fixed << std::setprecision(2) << obj->rect_params.width << ","
                      << std::fixed << std::setprecision(2) << obj->rect_params.height << ","
                      << std::fixed << std::setprecision(2) << obj->confidence << ";";
                  result += oss.str();
                  USER_LOG_INFO("Object: %s, Probability: %.2f, Box: (%.2f, %.2f, %.2f, %.2f)",
                obj->obj_label, obj->confidence, obj->rect_params.left, obj->rect_params.top, obj->rect_params.width, obj->rect_params.height);
            std_msgs::String msg;
            msg.data = result;
            if(PSDK_Wrapper::get_instance()->pubJianGeBang_position)
              PSDK_Wrapper::get_instance()->pubJianGeBang_position->publish(msg);
            PSDK_Wrapper::get_instance()->setResult(result);
      gst_buffer_unmap (buf, &in_map_info);
  catch(const std::exception& e)
    USER_LOG_INFO("osd_sink_pad_buffer_probe std::exception in");
    USER_LOG_INFO("error info :{}",e.what());
  catch (...) {
    USER_LOG_INFO("osd_sink_pa_budffer_probe unknow error");
static void LogFunction(GstDebugCategory \*category, GstDebugLevel level,
                        const gchar \*file, const gchar \*function, gint line,
                        GObject \*object, GstDebugMessage \*message,
                        gpointer user_data) {
  //spdlog::info("{}:{}", gst_debug_message_get(message), user_data);
  USER_LOG_INFO("%s:%p", gst_debug_message_get(message), user_data);
bool DeepStream::initPipe(std::string model_path, int interval)
  pipeline = gst_pipeline_new("pipeline");
  if (!pipeline) {
    USER_LOG_INFO("failed to gst_pipeline_new");
    return false;
  src = gst_element_factory_make("appsrc", "src");
  if (!src) {
    USER_LOG_INFO("failed to gst_element_factory_make appsrc ");
     return false;
  queue = gst_element_factory_make("queue", "queue");
  if (!queue) {
    USER_LOG_INFO("failed to gst_element_factory_make queue ");
        return false;
  parser = gst_element_factory_make("h264parse", "parse");
  if (!parser) {
    USER_LOG_INFO("failed to gst_element_factory_make h264parse ");
       return false;
  decoder = gst_element_factory_make("nvv4l2decoder", "decoder");
  if (!decoder) {
    USER_LOG_INFO("failed to gst_element_factory_make nvv4l2decoder ");
      return false;
  convert = gst_element_factory_make("nvvideoconvert", "convert");
  if (!convert) {
    USER_LOG_INFO("failed to gst_element_factory_make nvvideoconvert ");
     return false;
  mux = gst_element_factory_make("nvstreammux", "stream-muxer");
  if (!mux) {
    USER_LOG_INFO("failed to gst_element_factory_make mux ");
     return false;
  infer =
      gst_element_factory_make("nvinfer", "primary-nvinference-engine");
  if (!infer) {
    USER_LOG_INFO("failed to gst_element_factory_make nvinfer ");
    return false;
  convert2= gst_element_factory_make ("nvvideoconvert", "converter2");
  if(!convert){
      return false;
  /\* Create OSD to draw on the converted RGBA buffer \*/
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  if(!nvosd){
     USER_LOG_INFO("failed to gst_element_factory_make nvdsosd ");
      return false;
  sink = gst_element_factory_make("fakesink", "sink");
  GstPad \*osd_sink_pad = gst_element_get_static_pad(this->nvosd, "sink");
  gst_pad_add_probe(osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
                      osd_sink_pad_buffer_probe, NULL, NULL);
  g_object_set(src, "stream-type", GST_APP_STREAM_TYPE_STREAM, "format",
               GST_FORMAT_TIME, "do-timestamp", TRUE, "is-live", TRUE, "block",
               FALSE, nullptr);
  g_object_set(decoder, "enable-max-performance", TRUE,
               "enable-frame-type-reporting", FALSE, "enable-error-check",
               FALSE, "disable-dpb", TRUE, nullptr);
  g_object_set(infer,
                 "config-file-path", model_path.c_str(),
         "interval",interval,
                  NULL);
    g_object_set(mux,
                 "width", 1920,
                 "height", 1200,
         //"width", 640,
                 //"height", 640,
                 "batch-size", 1,
                 "compute-hw", 1,
                 "interpolation-method", 6,
                 "live-source",TRUE,
                 nullptr);
  gst_bin_add_many(GST_BIN(pipeline), src, queue, parser, decoder, convert,mux, infer, convert2, nvosd, sink, nullptr);
  if (gst_element_link_many(src, queue, parser, decoder,nullptr)==false){
    USER_LOG_INFO("failed to link element from mux to dst1");
    return false;
  if (gst_element_link_many(mux, infer, convert2, nvosd, sink,
                            nullptr) == false) {
    USER_LOG_INFO("failed to link element from convert2 to nvosd");
    return false;
    GstPad\* decoder_src_pad=gst_element_get_static_pad(decoder,"src");
    if (!decoder_src_pad)
        USER_LOG_INFO("tee request src1 pad failed. Exiting.");
    return false;
    GstPad \*mux_sink0_pad = gst_element_get_request_pad(mux, "sink_0");
    if (!mux_sink0_pad)
        USER_LOG_INFO("queue1 request sink pad failed. Exiting");
    return false;
    if(gst_pad_link(decoder_src_pad,mux_sink0_pad)!=GST_PAD_LINK_OK){
        USER_LOG_INFO("Failed to link tee_src0 and queue1_sink Exiting.");
    return false;
  ROS_INFO("\*\*\*\*\*\*\*\*\*\*\*\*initPipe OK \*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*");
  return true;
void DeepStream::unPipeData()
   gst_object_unref(GST_OBJECT(pipeline));
  // gst_object_unref(pipeline);
  // pipeline = nullptr;
  // gst_object_unref(dst1);
  // gst_object_unref(dst2);
  // gst_object_unref(src);
  // g_main_loop_unref(loop);
  // gst_object_unref(mux);
  // gst_object_unref(infer);
  // gst_object_unref(convert2);
  // gst_object_unref(nvosd);
  // gst_object_unref(encoder1);
  // gst_object_unref(parser1);
  // gst_object_unref(flv1);
  // gst_object_unref(queue);
  // gst_object_unref(parser);
  // gst_object_unref(decoder);
  // gst_object_unref(convert);
DeepStream::DeepStream() {
  gst_init(NULL, NULL);
  gst_debug_add_log_function(LogFunction, NULL, NULL);
  gst_debug_set_default_threshold(GstDebugLevel::GST_LEVEL_ERROR);
DeepStream::\~DeepStream() {
  unPipeData();
bool DeepStream::start(std::string model_path, int interval) {
  if (is_living || is_starting) {
   USER_LOG_INFO("already start or in starting status");
    return true;
  is_starting=true;
  USER_LOG_INFO("init dji module success initPipe 01");
  if(!initPipe(model_path, interval))
    is_starting=false;
    return false;
  USER_LOG_INFO("init dji module success initPipe 02");
  auto s = gst_element_set_state(pipeline, GST_STATE_PLAYING);
  if (s == GST_STATE_CHANGE_FAILURE) {
   USER_LOG_INFO("failed to set state to playing:{}",
                 gst_element_state_change_return_get_name(s));
    is_starting=false;
    return false;
  is_StreamInited=true;
  is_living=true;
  is_starting=false;
  return true;
void DeepStream::send(const uint8_t \*data, int dataLen) {
  //ROS_INFO("send 000\*\*\*\*\*\* ");
  if(!is_living)
    return;
  GstBuffer \*gstDecodeBuffer;
    GstFlowReturn ret;
  //ROS_INFO("send 111\*\*\*\*\*\* ");
     gstDecodeBuffer = gst_buffer_new_allocate(nullptr, dataLen, nullptr);
     gst_buffer_fill(gstDecodeBuffer, 0, data, dataLen);
     ret = gst_app_src_push_buffer(GST_APP_SRC(src), gstDecodeBuffer);
     if (ret != GST_FLOW_OK) {
    gst_buffer_unref(gstDecodeBuffer);
        USER_LOG_INFO("Gstreamer appSrc push buffer error!");
   //ROS_INFO("send OK\*\*\*\*\*\* ");
bool DeepStream::stop() {
  if (is_exiting) {
    USER_LOG_INFO("already stop or in stoping status");
    return true;
  is_exiting = true;
  bool result = true;
  is_living = false;
  unPipeData();
  is_exiting = false;
  return result;
First things first, please use ``` when copy-pasting stack traces or code (I’ve edited your post to use that)
otherwise it’s not really readable.
Unable to judge the bug from the code, some tips:
1.Rebuild you program with -g compile options, so that gdb can parse the callstack.
2.Use systemd-coredump to collect program crash callstack.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
