NVIDIA GeForce GTX 1650
deepstream:7.1-triton-multiarch
TensorRT version 10.3.0
Driver Version: 560.81
I am trying to create a module using PGIE resnet34_peoplenet_int8 model and SGIE retinaface_resnet50 model and used sgie_src_pad_buffer_probe and osd_sink_pad_buffer_probe. Pgie is working as expected since i used the deepstream sample_apps test2. Encountering this…
# python3 multicam.py file:///opt/nvidia/deepstream/deepstream-7.1/samples/streams/sample_1080p_h264.mp4 file:///opt/nvidia/deepstream/deepstream-7.1/samples/streams/sample-videos/face-demographics-walking-and-pause.mp4
[INFO] Creating pipeline...
[INFO] Received 2 source URIs:
[INFO] Creating nvstreammux...
[INFO] Creating source bin for stream 0...
[INFO] Linked source bin 0 to streammux
[INFO] Creating source bin for stream 1...
[INFO] Linked source bin 1 to streammux
[INFO] Creating processing elements and queues...
[INFO] Linking elements with queues...
[INFO] Pipeline elements linked successfully.
[INFO] Setting pipeline to PLAYING...
0:00:01.641733519 1476928 0x557a0064fa60 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1243> [UID = 2]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:01.885364030 1476928 0x557a0064fa60 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/samples/models/retinaface-onnx/weights/retinaface_resnet50.onnx_b2_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [FullDims Engine Info]: layers num: 4
0 INPUT kFLOAT input 3x640x640 min: 1x3x640x640 opt: 2x3x640x640 Max: 2x3x640x640
1 OUTPUT kFLOAT bbox 16800x4 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT confidence 16800x2 min: 0 opt: 0 Max: 0
3 OUTPUT kFLOAT landmark 16800x10 min: 0 opt: 0 Max: 0
0:00:01.885443561 1476928 0x557a0064fa60 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/samples/models/retinaface-onnx/weights/retinaface_resnet50.onnx_b2_gpu0_int8.engine
0:00:01.894263501 1476928 0x557a0064fa60 WARN nvinfer gstnvinfer.cpp:1063:gst_nvinfer_start:<secondary1-nvinference-engine> warning: NvInfer asynchronous mode is applicable for secondaryclassifiers only. Turning off asynchronous mode
0:00:01.894788665 1476928 0x557a0064fa60 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:face_detect_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:02.114490577 1476928 0x557a0064fa60 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b2_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT input_1:0 3x544x960 min: 1x3x544x960 opt: 2x3x544x960 Max: 2x3x544x960
1 OUTPUT kFLOAT output_cov/Sigmoid:0 4x34x60 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT output_bbox/BiasAdd:0 16x34x60 min: 0 opt: 0 Max: 0
0:00:02.114564769 1476928 0x557a0064fa60 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b2_gpu0_int8.engine
0:00:02.118990176 1476928 0x557a0064fa60 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest2_pgie_config.txt sucessfully
[INFO] Pipeline is now playing.
[INFO] Starting GLib Main Loop. Press Ctrl+C to stop.
Failed to query video capabilities: Inappropriate ioctl for device
[DEBUG] Found video pad: video/x-raw, format=(string)Y444, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], pixel-aspect-ratio=(fraction)1/1; video/x-raw, format=(string)Y444_10LE, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], pixel-aspect-ratio=(fraction)1/1; video/x-raw, format=(string)P010_10LE, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], pixel-aspect-ratio=(fraction)1/1; video/x-raw, format=(string)NV12, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], pixel-aspect-ratio=(fraction)1/1, adding convert chain
[DEBUG] Source bin pad linked via NVMM convert chain
Parse function for .so generation
#include "nvdsinfer_custom_impl.h"
#include <algorithm>
#include <cmath>
#include <cstring>
#include <iostream>
#include <vector>
#define CONF_THRESH 0.1f // Minimum face confidence to keep
#define NMS_THRESH 0.4f // IoU threshold for NMS
#define VIS_THRESH 0.75f // (optional) Additional threshold before output
struct Detection {
float x1, y1, x2, y2; // pixel coordinates
float score;
static float iou(const Detection &a, const Detection &b)
float x_left = std::max(a.x1, b.x1);
float y_top = std::max(a.y1, b.y1);
float x_right = std::min(a.x2, b.x2);
float y_bottom = std::min(a.y2, b.y2);
if (x_right <= x_left || y_bottom <= y_top)
return 0.0f;
float inter_area = (x_right - x_left) * (y_bottom - y_top);
float area_a = (a.x2 - a.x1) * (a.y2 - a.y1);
float area_b = (b.x2 - b.x1) * (b.y2 - b.y1);
return inter_area / (area_a + area_b - inter_area);
static void run_nms(std::vector<Detection> &input, float nms_thresh,
std::vector<Detection> &output)
std::sort(input.begin(), input.end(),
[](const Detection &a, const Detection &b) {
return a.score > b.score;
std::vector<bool> suppressed(input.size(), false);
for (size_t i = 0; i < input.size(); ++i) {
if (suppressed[i])
continue;
output.push_back(input[i]);
for (size_t j = i + 1; j < input.size(); ++j) {
if (suppressed[j])
continue;
float overlap = iou(input[i], input[j]);
if (overlap > nms_thresh) {
suppressed[j] = true;
static bool NvDsInferParseRetinaface(
std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
NvDsInferNetworkInfo const &networkInfo,
NvDsInferParseDetectionParams const &detectionParams,
std::vector<NvDsInferObjectDetectionInfo> &objectList)
const NvDsInferLayerInfo *bboxLayer = nullptr;
const NvDsInferLayerInfo *confLayer = nullptr;
const NvDsInferLayerInfo *landmarkLayer = nullptr;
for (auto const &layer : outputLayersInfo) {
if (strcmp(layer.layerName, "bbox") == 0) {
bboxLayer = &layer;
} else if (strcmp(layer.layerName, "confidence") == 0) {
confLayer = &layer;
} else if (strcmp(layer.layerName, "landmark") == 0) {
landmarkLayer = &layer; // if you want landmarks later
if (!bboxLayer || !confLayer) {
std::cerr << "ERROR: Missing output layers (expect 'bbox' and 'confidence').\n";
return false;
// 2. Extract pointers to raw buffers
float *bboxData = (float *)bboxLayer->buffer; // shape: [16800 × 4]
float *confData = (float *)confLayer->buffer; // shape: [16800 × 2]
int numAnchors = bboxLayer->inferDims.d[0]; // (= 16800)
std::vector<Detection> candidates;
candidates.reserve(numAnchors);
const float imgW = static_cast<float>(networkInfo.width);
const float imgH = static_cast<float>(networkInfo.height);
for (int i = 0; i < numAnchors; ++i) {
float faceScore = confData[i * 2 + 1];
if (faceScore < CONF_THRESH)
continue;
float nx1 = bboxData[i * 4 + 0];
float ny1 = bboxData[i * 4 + 1];
float nx2 = bboxData[i * 4 + 2];
float ny2 = bboxData[i * 4 + 3];
// Convert to pixel space and clip
float x1 = std::max(0.0f, std::min(nx1 * imgW, imgW - 1.0f));
float y1 = std::max(0.0f, std::min(ny1 * imgH, imgH - 1.0f));
float x2 = std::max(0.0f, std::min(nx2 * imgW, imgW - 1.0f));
float y2 = std::max(0.0f, std::min(ny2 * imgH, imgH - 1.0f));
// Make sure box is valid
if (x2 <= x1 || y2 <= y1)
continue;
// Store candidate
Detection d;
d.x1 = x1;
d.y1 = y1;
d.x2 = x2;
d.y2 = y2;
d.score = faceScore;
candidates.push_back(d);
if (candidates.empty())
return true; // no detections above CONF_THRESH
// 5. Run NMS (IoU > NMS_THRESH)
std::vector<Detection> keep;
keep.reserve(candidates.size());
run_nms(candidates, NMS_THRESH, keep);
// 6. Convert final boxes into DeepStream’s NvDsInferObjectDetectionInfo
for (auto &det : keep) {
if (det.score < VIS_THRESH)
continue;
NvDsInferObjectDetectionInfo out;
out.classId = 0; // “face” is class 0
out.detectionConfidence = det.score;
out.left = static_cast<unsigned int>(det.x1);
out.top = static_cast<unsigned int>(det.y1);
out.width = static_cast<unsigned int>(det.x2 - det.x1);
out.height = static_cast<unsigned int>(det.y2 - det.y1);
objectList.push_back(out);
return true;
extern "C" bool NvDsInferParseCustomRetinaface(
return NvDsInferParseRetinaface(
outputLayersInfo, networkInfo, detectionParams, objectList);
// Compile‐time check that the function signature matches what DeepStream expects.
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomRetinaface);
dstest2_pgie_config.txt.txt (803 Bytes)
(PGIE CONFIG)
face_detect_config.txt (914 Bytes) (SGIE CONFIG)
